Ultimate Dual PIII-S Rig
First post, by Obijuan1983
After years searching this specific hardware, I finally got an ASUS CUV4X-DLS Dual s370 socket , 2x Lin-Lin adapters , 2 x PIII-S 1.4GHz Tualatin and 2 x Aftermarket Heatsinks, all at 50 Euros!
The Rig for testing has:
ASUS CUV4X-DLS (Dual socket s370, Ethernet , SCSI adapter)
2 x Pentium III-S 1.4GHz Tualatin (1400/512/134)
1GB RAM (4 x 256MB PC133)
ATI X1650PRO 256 MB DDR3
Creative Audigy
Windows 7 32bit
Waiting for 2GB RAM (4x512MB PC133) , an PCI to SATA adapter to connect an 120GB SSD, 2 x Waterblocks to watercool the CPU's and a new windowed case.
1.28 MiB
1.58 MiB
421.64 KiB
325.66 KiB
1.45 MiB
Reply 1 of 31, by Obijuan1983
Windows 7 32bit
2 x Pentium III-S 1.4GHz @ 1.625GHz (Lin-Lin adapters voltage 1.6v )
1GB RAM
411.6 KiB
SPi1M @ 1.625GHz
437.86 KiB
Windows XP Home (SMP not supported)
SPi1M
PIII-S @ 1.625GHz, Memory @ 155MHz 2-2-2-6
293.14 KiB
Reply 2 of 31, by Intel486dx33
Nice motherboard. It support Win95b, NT-4.0 and Win98 too.
Reply 5 of 31, by chinny22
P3 with Win7? I'm still running WinXP on Socket 775. 🤣!
I get what your trying to do though, Will be an interesting build indeed
Reply 6 of 31, by eisapc
Why dont you install Pro with SMP support? I cant remember installing the Home edition anywhere.
eisapc
Reply 7 of 31, by Obijuan1983
2 x Pentium III-S 1.4 @ 1.68GHz ( Full Stable )
wPrime 1024M
271.02 KiB
And for comparison
2 x Pentium III EB 1.0GHz @ 1.2GHz
wPrime 1024M
276.93 KiB
Reply 8 of 31, by luckybob
I always encourage dual cpu builds. Don't be shy, just pirate the proper operating system.
One of these days I'm going to have to educate the masses to the REAL ultimate.
Reply 9 of 31, by looking4awayout
Being an overclocked Pentium III-S user, I'm quite interested in your system. Did you need to mod your BIOS in order to support the Tualatins on your motherboard? In my case I have a native Tualatin motherboard, a QDI Advance 10T, running a pin modded CPU I bought from the renown South Korean ebayer. I managed to raise the FSB through software (CPUFSB, as there's no way to do it through BIOS) up to 147MHz and runs stable, but if I go beyond I start getting BSODs and random freezes. I mostly would be interested in the CUV4X if it lets me use the Tualatin without having to tamper with the BIOS and if it lets me overclock straight from it, rather than using CPUFSB in Windows. The graphics card I use in my case is an overclocked ATI Radeon X1950 Pro, works like a charm, the entire system is very fast and snappy. In my case I run my RAM (x3 Infineon PC133 CL2 sticks) at CAS2 Turbo mode.
I highly recommend you to put an X1950 Pro on that system, overclock the card to the maximum stable limit, and you'll get quite a speed demon. 😎
My Retro Daily Driver: Pentium !!!-S 1.7GHz | 3GB PC166 ECC SDRAM | Geforce 6800 Ultra 256MB | 128GB Lite-On SSD + 500GB WD Blue SSD | ESS Allegro PCI | Windows XP Professional SP3
Reply 10 of 31, by Obijuan1983
At the ASUS CUV4X-DLS I use 2 x Pentium III-S 1.4GHz Tualatin with 2 x Lin-Lin adapters.I didn't modded the Bios and I can overclock them until 1.74GHz (10.5x166FSB ) at 1.675v with the voltage selection (with jumpers of the Lin-Lin adapters). The max FSB of the motherboard is 166MHz.
Reply 11 of 31, by looking4awayout
Interesting... Does the BIOS let you change the FSB? Mine doesn't, forcing me to use CPUFSB in Windows.
Reply 12 of 31, by Obijuan1983
Yes you can adjust FSB via Bios settings.
765.29 KiB
Reply 13 of 31, by looking4awayout
That is very cool, thanks! I will consider it as a future upgrade for my RDD.
Reply 15 of 31, by looking4awayout
Honestly I'd be happy to get even a single CPU one, as I've reached outstanding performance with the current motherboard I have. By the way, what kind of RAM are you using? I have Infineon CL2 modules in my build, but they are stable only up to 147MHz and then they crap out.
Reply 16 of 31, by Obijuan1983
For Benches I have 1x128MB PC133 cl2 reaching 166+MHz 2-2-2-5
For Windows 7 32bit 1GB RAM , 4x256MB PC133 CL3 Reaching 166+MHz 3-3-3-6
I will upgrade to 2GB RAM 4x512MB PC133 CL3 soon
Reply 17 of 31, by Obijuan1983
Max Post
2 x Pentium III-S 1.4GHz @ 1.725GHz
249.57 KiB
SPi 32M
2 x Pentium III-S @ 1.68GHz
291.42 KiB
Reply 18 of 31, by Obijuan1983
Today I started to build the rig in the modded case I had.
Its a Lian-Li PC60, painted black inside and added a side window.
I also did a cable modding to hide the 24pin ATX cable and power button.
Waiting for the PCI to SATA adapter to add the SSD and 2 GB RAM (4x512MB PC 133)
Next step is to watercool the dual PIII-S...
700.94 KiB
1.34 MiB
1.3 MiB
978.85 KiB
Reply 19 of 31, by Intel486dx33
I would put Win98es on it for gaming if it supports dual cpu’s ?
If not I would use Win2000 Pro.
Max ram
Voodoo 3 agp
Sound blaster audio 2zs with live drive.
Intel Network card 1gb.
Klipsch 2,1 Media Pro speakers.
I have some of those Liam Li cases and I really like them.
