Retro Rig Photo Thread
Reply 1500 of 3223, by overdrive333
NuuttiS wrote:
I'm slowly building a system to play early to mid 90's games. Finally found a case with turbo switch and MHz display. Still need […]
I'm slowly building a system to play early to mid 90's games. Finally found a case with turbo switch and MHz display. Still need to get MT-32 and Gravis Ultrasound.
AMD 486 DX/2 66MHz, 8Mb RAM
Sound Blaster 16 CT1740
S3 Trio64
14" ICL shadowmask display with all analog controls for older games
19" Samsung 959NF for newer games
file.php?id=58038&t=1
My case/cd-rom brother 😈 . But what's inside? Who will guess?
Reply 1501 of 3223, by Bancho
Some variant of a Gigabyte Board VX/HX/TX? A variant of Sound Blaster (1.5, 2 Pro?) Cant figure out the graphics card though 🤣
Reply 1502 of 3223, by overdrive333
Not even close 😈
Reply 1503 of 3223, by Bige4u
Just picked up a Jaton GF2 MX400 64mb PCI video card..... last owner says it has issues with i810/i815 chipsets and through experimentation, it only works with the v56.64 win98 driver(confirmed), it works and stable in DOS and 2D, but only in 16bit and not 32bit colors while gaming, and the clocks show for both GPU and MEM are the same @ 143 instead of 200/166 anyone ever heard of such a problem?
I figure i'd use this video card in a slot1 500mhz system of with the motherboard uses the 440BX chipset since its a wee bit more powerful than the VooDoo3 3000 16mb agp2x video card i have at the moment and see how that fairs.
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 1504 of 3223, by overdrive333
Why need to use PCI videocard in 440bx system? 😀
Reply 1505 of 3223, by Bige4u
Just realized i posted my last posting about the videocard in the wrong place. Cant Delete
Reply 1506 of 3223, by gdjacobs
Something like an All in Wonder?
Reply 1507 of 3223, by overdrive333
Reply 1508 of 3223, by PcBytes
overdrive333 wrote:
Matrox Millenium?
Reply 1509 of 3223, by oohms
looks like a voodoo rush
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 1510 of 3223, by overdrive333
Reply 1511 of 3223, by gdjacobs
Ooh! Intergraph Intense 3d or California 3d Emotion?
Reply 1512 of 3223, by overdrive333
A-Trend ATC-2475
Taken pci400-4
Am5x86-133 @ 150mhz(50x3)
SB16 CT2740
Reply 1513 of 3223, by Socket3
Bige4u wrote:
I ran a K6-3/500mhz system once a long time ago.... the ultimate space heater it was, no joke.
I don't think so. K6 CPUs (I/II and especially II+ and III) are remarkably cool. A standard small socket 7 cooler is enough to cool a 500Mhz K6-III.
Zack_H wrote:
My Dad used to have one too! That’s I actually why I initially got one again, but then It turned out to be a really great mobile […]
oeuvre wrote:
oh man my dad had one and the battery on it never worked right though
My Dad used to have one too! That’s I actually why I initially got one again, but then It turned out to be a really great mobile vintage machine for me!
bjwil1991 wrote:
I have 4 Pentium 4 laptops that have Radeon Mobile 7500 or 9000 prospectively: […]
1) IBM ThinkPad R40 (Pentium 4-M 2GHz, Radeon 7500 16MB)
2) 2x Dell Inspiron 600m (Celeron, Radeon 9000 32MB & Centrino, Radeon 9000 32MB)
3) Dell Latitude D600 (Centrino, Radeon 9000 32MB)
Cool! While we’re on the subject of Pentium 4 laptops, here’s one I dearly love. The Dell Inspiron 8200! This is the updated version of the 8100. Notice those cool silver palm rests!
This particular one has a 1.8GHz Pentium 4 Mobile, and an ATi Radeon 9000 64MB graphics card! It’s my primary Windows XP machine, and man does it run XP well!
Mine also has what Dell called their “UltraSharp” display. It’s the same 1600 x 1200 resolution, but it’s brighter, has a wider viewing angle, and a higher contrast ratio than their standard UXGA display. I got lucky with this 8200, because it’s basically a top-end model. Someone definitely payed an arm and a leg for this thing when it was new!
I just love the Inspiron 8000 series laptops. They’re just fantastic in my opinion.
I have two almost identical machines. One is a 1.5GHz pentium 4 with a Geforce 2 GO video card, the other is a 2GHz model with a radeon 9000. Both have black palmrests tough, and the speakers are dead on both of them... Oh an I found a large 7.2v rechargeable battery inside both witch leaked. That killed one of the laptops (the GF2 model) but the other one didn't sustain much damage.
I strongly suggest you crack yours open and replace this battery:
Reply 1514 of 3223, by appiah4
Completely restored Dell Dimension XPS D333 with some upgrades (marked with asterisk in the specs below)
Specs
Motherboard: Dell 7207C i440LX
CPU: Intel Pentium II 333MHz
RAM*: 192MB SDRAM
Storage 1: IBM 8,4GB IDE
Storage 2*: Maxtor 80GB IDE
Optical*: Samsung 16x DVD/CD-RW Combo
Graphics 1: STB Riva 128 4M
Graphics 2*: Pixelview Voodoo II-T 12M
Video Decoder: QI Cinemaster C 1.2
Audio 1: Turtle Beach Montego
Audio 2*: Creative Sound Blaster AWE6 Value
Network*: 3Com 3c905 10/100Mbit
OS: Windows 98SE
Reply 1515 of 3223, by oeuvre
retrobright those front panels and it'll look great
Reply 1516 of 3223, by appiah4
Side panels and top are also yellowe and honestly I can live with this much yellow 😀 This will likely be my go-to retro PC for a long time.
I wanted to squeeze in a Voodoo 2 SLI but I could not bring myself to do away with any of the PCI cards in there..
Reply 1517 of 3223, by corsaira
Reply 1518 of 3223, by gdjacobs
What Athlon MPs did you go with?
Reply 1519 of 3223, by Tetrium
There is no K6-III 500MHz, or at least not officially. I presume you meant to say K6-III+?
K6-III was actually kinda hot for a (super) socket 7 CPU and official ones were released up to 450MHz.
My retro rigs (old topic)
Report spammers here!
