Retro Rig Photo Thread
Reply 1540 of 2762, by MMaximus
dr.ido wrote:
Caluser2000 wrote:
Xenon 2?
definitely!
Hard Disk Sounds
Reply 1541 of 2762, by PcBytes
simprato wrote:
Hi, that's my "new" retro-gaming PC […]
ABIT BF6 (i440BX chipset)
Celeron II 900Mhz @1000Mhz
Cooler Master Heatsink with 5000RPM ball bearing fan
1x256Mb PC133 C3
3DFX Voodoo3 2000 AGP @175mhz
Sound Blaser Live! Value
HPT370A PCI IDE RAID ATA-100
Realtek RTL8139B 10/100 LAN
Maxtor D740X-6L 20GB HDD (hydraulic bearing!)
Pioneer DVD-ROM snap-in 10x/40x
ASUS CDRW 4816A
Deer 230W PSU
ATX Case of 1999
Windows ME with security CD 2004
Umm.... is it me, or were the IDE ports on the mobo removed?
Reply 1542 of 2762, by bjwil1991
My wild guess is the person that had that board removed them due to the IDE controller issue on the board itself?
Reply 1545 of 2762, by SpectriaForce
wirerogue wrote:
new pentium iii build. […]
asus tusl2-c
pentium iii tualatin @ 1.6ghz
384 pc133 memory
geforce4 ti4600
soundblaster audigy
antec 300w psu
new generic case (looks nice, murder to build in)
windows 98
Nice, looks very period correct. But I think that it should run Windows 2000 or ME 😊
Reply 1546 of 2762, by simprato
No, the BF6 is essentially a BE6-II without HighPoint ATA-66. I've installed an ADAPTEC 1200A which is a HighPoint but ATA-100.
Reply 1547 of 2762, by wirerogue
new pentium 4 build.
abit is7-e2
pentium 4 3.4ghz
cooler master hyper 6 cpu cooler
2x1gb patriot pc3200 memory
bfg geforce 6800gt oc
soundblaster audigy 2
evga 550 g2 psu
chenbro SR20969 workstation chassis
windows 2000
Reply 1548 of 2762, by Caluser2000
Here's my 386DX25 rig:
Sports 8megs of ram, 4gig BigFoot hdd with EZDrive DDO. It is running MS Dos 6.22 along with Windows for Worgroups 3.11 fully networked and has a ISA sound card which is SB/Alib compatible. Apart from the cmos battery being low it works wonderfully well. Haven't identified the battery location as it is not your standard type. Not Dallas or any other sort I'm familiar with. I do know it charges though. The system was given to me and dropped off under my carport one day. Originally it had a 100meg Apple branded SCSI drive and controller. Not having any SCSI drives to replaced it with a IDE controller and drive were fitted. I fitted the the CD drive as I had plenty spare. Put together by MITEK, a local company still in operation today in 1990. An unusual thing about it is it has It has a sliding cover over the 5.25" fdd and CDRom drives.
Reply 1549 of 2762, by MMaximus
Nice little system. I don't know what you used to take the picture but the white balance and the softness makes it look like you took this photo in 1990 🤣
Hard Disk Sounds
Reply 1550 of 2762, by Caluser2000
Using a very old Genius G-Shot P210 2.1 mega pixel camera so yeah.
Reply 1551 of 2762, by lvader
Here is my Commodore 64 setup.
Reply 1552 of 2762, by kikendo
Basically finished after months: My Gateway 2000 Pentium II rig.
Pentium II @ 400 Mhz
128 MB RAM
STB Velocity (Riva 128) w/ 4MB RAM
Sound Blaster 16 Vibra
Intel PRO/100 NIC
16GB bracket-mounted CompactFlash as main hard dfrive
Gotek floppy emu running latest FlashFloppy v2.x
Lite-On CD-RW drive
InterAct PC Propad 4 controller
ESP8266-based home made WiFi modem.
The display, not pictured, is a 4:3 LCD LG Flatron
The case came from a G6-233 system, so even if not the original, it's as close as it gets. There is a lid that goes over the front covering thee Gotek and CD-RW drive, I have it, it's just not pictured (it won't fir with that Gotek USB stick on)
The OS is Windows 98 SE
Sadly, the original floppy and CD drive don't work, so I have some work left to do trying to restore those two to original condition, but that's not bad considering the state I received this thing in. I never seen a filthier machine.
Other than that, I consider this system pretty much finished!
BIG THANKS to the Vogons community for all the help while I was building this. The people and drivers database found here have been invaluable in restoring this system!
Reply 1553 of 2762, by oeuvre
also try to find a replacement door!
Reply 1554 of 2762, by kikendo
Was that a message for me? I already mentioned in the post that I have the "door"(the front panel cover).
Reply 1555 of 2762, by JonathonWyble
He might have been referring to an early post by user simprato, who posted pics of his rig without its panel. I think...
1998 Pentium II build
Reply 1556 of 2762, by oeuvre
I'll leave it up to you guys to figure it out.
Reply 1557 of 2762, by SpectriaForce
wirerogue wrote:
new pentium 4 build. […]
abit is7-e2
pentium 4 3.4ghz
evga 550 g2 psu
windows 2000
I like the case, it has a clean professional look without curves, which matters when it comes to a computer 😊
Reply 1558 of 2762, by SpectriaForce
Looks like it is a photo from 1985, very period correct 😀
Reply 1559 of 2762, by Almoststew1990
My little Dell doesn't need its own thread so here are some before and after pictures...
