TinyLlama 3
Reply 20 of 33, by ahmadexp
By the way, since you are using the CM4, I have some previous projects with it which build a CM4 "sandwich". Here is a link to the github with all the projects. https://github.com/opencomputeproject/Time-Ap … bation/Hardware
Reply 21 of 33, by snipe3687
ahmadexp wrote on 2024-05-17, 14:41:
Please don't drop the ESP8266. I love the retro modem so much.
Same! Maybe there’s a way to even integrated directly into the board but hey, I’m not designing it so it’s easy to make that when you don’t have to figure out where to squeeze it 🤣
Reply 22 of 33, by Eivind
The CM4 can easily emulate a modem, same as the ESP8266. 😉
The LlamaBlaster sound card
ITX-Llama motherboard
TinyLlama SBC
Reply 23 of 33, by snipe3687
Eivind wrote on 2024-05-17, 16:04:
See, that's why you get paid the big bucks! Can't wait to build one.
Reply 24 of 33, by snipe3687
I noticed you have the CH559 chip on the schematic. I’m wondering since you have an RP2040 on the ITX for the HID that works nicely and the picoGus has the USB joystick functionality, couldn’t you leverage that for the HID somehow? It would save some space on the board.
Just a curiosity really.
Reply 25 of 33, by Eivind
snipe3687 wrote on 2024-05-19, 14:35:
The PicoGUS firmware doesn't support USB-to-PS/2 translation, and even if it did you'd still only have a single port (the one currently used for joysticks). For two USB ports (like I use the RP2040 on the ITX-Llama) you need to leverage the PIO functionality of the RP2040. That's not available on the PicoGUS, because it's being used for ISA bus communication.
As for why I've used the CH559 instead of another RP2040 - mostly because it's a simpler and cheaper design. The only drawback is support for certain USB hubs - but rasteri is currently working hard on getting that improved in his HIDman firmware, and I'm helping out as best as I can. If it turns out that the RP2040 will be a better solution after all, I'll use that instead. I'm still working on basic component layout for the board, so there should be plenty of time to make changes if needed.
TinyLlama SBC
Reply 26 of 33, by ahmadexp
So, the CM4 is going to do MT32pi as well as retro modem?
Reply 27 of 33, by Eivind
ahmadexp wrote on 2024-05-19, 16:59:
I wasn't thinking mt32-pi (though I suppose you could do that as well). But rather a standard linux distro with several services running.
The CM4 has more than enough IO and horsepower to do lots of things, it's not really necessary to run a bare-metal solution like mt32-pi. I think I've mentioned all of these before, but here's a recap:
2 x uart (3mbps) for modem/ethernet and floppy
1 x uart for midi input from the PicoGUS (running munt/fluidsynth/whatever software synth you want)
1 x i2s audio output
1 x i2c - for anything, really. the SOM and fan controller are also connected to this bus.
TinyLlama SBC
Reply 28 of 33, by ahmadexp
Eivind wrote on 2024-05-19, 17:15:
I wasn't thinking mt32-pi (though I suppose you could do that as well). But rather a standard linux distro with several services […]
Oh that would be freaking awesome. If we can have a none bare metal emulation of MT32 with more features, that would be so awesome.
Please consider routing the CSI pins from the CM4 to a TC358743XBG. This will allow you to have HDMI input.
Ultimately, we can have the option of routing the video output (with the miniPCIe VGA solution with HDMI) to be sent remotely.
That will allow you to have your MS-DOS or Win98 box accessible via your very own KVM. Pi-KVM can be easily used for this purpose.
Just an idea though, but I think it will make the super awesome.
You know, regardless, I am a huge fan of your sequel of TinyLlamas and I am very thankful to you.
Reply 29 of 33, by Eivind
ahmadexp wrote on 2024-05-20, 03:37:
Please consider routing the CSI pins from the CM4 to a TC358743XBG. This will allow you to have HDMI input. Ultimately, we can […]
Heh, that is a very cool idea! Gotta say though - it seems quite niche, not sure it'd be worth it for most of the small (I assume) number of people wanting to build this thing... 😉
Do you think it might work to simply route the CSI lines out to a pin header, so one could plug in a small addon board for this specific use case? I mean, the CSI signal will be quite high-speed I think - do you know if this should be viable from a signal integrity perspective...?
TinyLlama SBC
Reply 30 of 33, by ahmadexp
Eivind wrote on 2024-05-20, 08:52:
Oh yeah, if you put the standard CSI connector then it will be all good. Look at this module from Waveshare https://www.waveshare.com/hdmi-to-csi-adapter.htm
Reply 31 of 33, by polpo
Eivind wrote on 2024-05-03, 09:23:
- Using an op amp for analog mixing of the two audio sources looks like an op amp not really needed for this simple mixing
Hi, PicoGUS creator here. Super cool to see this project as well as the LlamaBlaster, they have the perfect amount of audaciousness. 😁 Can't believe I didn't know about them until now!
I'd recommend using an op amp for the mixing... Using a 100% passive mixing circuit for the wavetable on the PicoGUS 2.0 is probably my only regret in the design. It sounds good but the volume level is definitely low. Usually you can just turn your speakers up more but if you're capturing for recording or streaming it can be annoying having to apply extra gain.
Reply 32 of 33, by Eivind
polpo wrote on 2024-05-22, 04:15:
Hey Ian, kudos on your awesome project and congrats on getting it out on serdashop! 😀
Interesting about the mixing... Have you measured the output of the PicoGUS 2.0? What kind of Vrms / Vpp does it show when playing something at full (software-level) volume? I might add an OPA1656 or something, just wondering if it makes sense to add gain or if a unity-gain setup would suffice. For the first prototype of the LlamaBlaster I used a gain of 1.4, and that almost seemed a bit over the top, as the 1656 has plenty of current-driving capability.
TinyLlama SBC
Reply 33 of 33, by Eivind
Update:
I haven't had as much time as I'd hoped, so this has gone rather slowly - but I'm getting there.
It was just too tight getting the board down to the Raspberry Pi size (85x56mm), but it's not going to be very much larger at least.
Here's a screenshot of my current progress:
325.69 KiB
I still have a few components left to place and route, as you can see. I may also add an op amp and a CSI connector, shouldn't be a problem.
TinyLlama SBC
