Reply 20 of 21, by PC Hoarder Patrol
- l33t
justin1985 wrote on 2023-01-20, 19:55:Thanks to PC Hoarder Patrol's extreme kindness, I've now been able to replace the CD-ROM cable - it not only works perfectly - b […]
PC Hoarder Patrol wrote on 2023-01-14, 19:04:Finally found the little beggar! 😀 ...it's the original cable from my own (currently busted) Deskpro SFF P3 450 - I replaced the original working CD-ROM drive and the new one came complete with cable.
Thanks to PC Hoarder Patrol's extreme kindness, I've now been able to replace the CD-ROM cable - it not only works perfectly - but - who'd have thought it - it seems to have greatly improved the "PC Thinking Noise" issue too! I guess where the old CD cable had worn through it had 'released' a lot more interference, nestled in right next to the internal speaker ...
The same day, the SoundBlaster Live! that I had ordered from eBay also arrived (an SB0220 - which I later learned is a model to avoid ...) and I've had some weirdness trying to fit it ...
First of all, I haven't been able to properly - when I disabled the onboard audio in the "Onboard Devices" section of the BIOS (cycle through several combinations of resource settings, last of which is disabled) - but even with it disabled in the BIOS (and the "Device Security" setting for audio enabled or disabled, whatever that does) - it still shows up - and works - in Windows.
I was able to install the drivers for the SB0220 using the driver file from the Vogons site, but when I rebooted the ESS card was still working, and in the Multimedia settings page in Windows only the ESS audio services were selectable for playback recording etc. I tried disabling the ESS devices in Windows Device Manager, which worked. But there still weren't any Creative devices in Multimedia Settings. So I thought I'd reinstall the drivers ... and that's when I hit something really weird ...
Since I installed the Creative drivers and rebooted - Windows hasn't been detecting any USB devices! At all! I even tried completely uninstalling the Creative drivers, but still zero luck detecting USB devices ... this does feel like a true reminder of Win98 days!
Any ideas? Is reinstalling Windows likely the only way to get USB working again?
That was quick! - glad it worked out OK 😀
