Well, I have good news. I had tried several combinations without luck until I found total hardware 99. I saw memory bank arrangement for my motherboard. I was wrong, I thought that the two first slots were bank 0 and the other two were bank 1, but no, they are mixed (first bank 0 simm 1, then bank 1 sim 2, then bank 0 simm 3 and the last one is bank 1 simm 4). So I tried the two last possible combinations. With first combination it doesn't boot. With the last possible combination...
BINGOOO!!!!!! They are arranged like this:
Bank 0: 8mb 6 chip modules.
Bank 1: 16mb 8 chip modules.
Now I have the furious amount of 48mb of EDO ram using my original 2x8mb sticks 😎
So I can conclude that I'm a little bit idiot and I have to read better the manuals/datasheet before doing things that I don't remember. This system is almost 21 years old and of course there are many things that I forgotten.
Another subject: we have 220 volts outlets here, while you have 110 volts. Maxisound's keyboards came with 110v power supplies for the amplifiers. Lets suposse that I buy a 220v transformer: the keyboard doesn't have any switch to turn off the amplifiers. I didn't like the idea of leaving it turned on, so I did this:
I drilled a hole in a bracket and screwed a connector. It's soldered to a molex (5v). I used the 12v connection to power the fan blower attached to the regulator. Resuming: one molex for two purposes. It's really neat.
I will come in next days with more updates. See you! 😎
