post up pics of your "computing area"
Reply 1340 of 2208, by sledge
@OldCat: Yep, CTM644! And somewhere under the table is fully working Amstrad / Schneider CPC 464 with Zaxon's DDI3 USB floppy emulator 😀
doshaven.eu / high-voltage.cz
Reply 1341 of 2208, by Caluser2000
My new arrangement.
1.42 MiB
Main setup in the conservatory. Systems left to right- HP P200mmx running Xandros 2.1, IBM PC300GL Celeron 400 minitower running Win98FE, Compaq Presario CDS524 MS Dos 6.22/Win3.1/GeoWorks, Zenith Z286LP Plus running MS Dos 5a and Windows 3.1,packet driver and Trumpet Winsock 1.0, 386DX25 running MS Dos 6.2 along with Wfw 3.11. All the systems on the desk/stand are networked via Cat5. 18.5" IBM P97 SVGA flat screen monitor shared by the 286 and 386 using a monitor switcher.
1.31 MiB
Taking over the kitchen table for testing. Left DEC 486LPv+ 425sx upgraded to 486DX2/66 16megs of ram running OS/2 v3 Warp. Right my wifes 2yo el cheapo AMD based HP laptop for downloading docs and software with external 3.5"usb floppy drive for imaging purposes. Runs Windows 10 Both networked.
1.34 MiB
Lounge with Linux box and a shelf with some software I've collected over the years. Connected to router by Cat5. Not quite the same as having the space of a whole double bedroom but hey.....
Reply 1343 of 2208, by OldCat
A fellow man of culture indeed. I also use Zaxon's floppy emulator, albeit a different one (for 6128, external).
234.67 KiB
Reply 1344 of 2208, by buckeye
oeuvre wrote:
https://i.imgur.com/rwON8All.jpg […]
Found this old one from 2008
Ah, I see you "upgraded" to a rotary phone, prefer a green one though 🤣
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 1345 of 2208, by JonathonWyble
Hmm... That leather couch on the far right makes it look like part of the setup, being the chair for the desk...
1998 Pentium II build
Reply 1347 of 2208, by keropi
^ great stuff here too I always like CRT screens with old systems, lcd don't cut it if you have the space
one day I will also find a nice IBM keyboard 😁
Reply 1350 of 2208, by Slot1
It wasn't that expensive, 30 euros plus shipping locally. For a legendary keyboard it isn't expensive. You can find them cheap locally, on ebay they are are way more expensive. It was all dirty when I got it, cleaned it and it looks brand new.
I'm always hunting for deals, not paying the crazy prices.
Reply 1351 of 2208, by oeuvre
yeah you can also find the lexmark ones cheaper too... practically the same experience anyways
Reply 1352 of 2208, by Zack_H
Here’s one of my “computing” tables. I have my Inspiron 8200 (my favorite Windows XP laptop of all-time) sitting here currently.
1.56 MiB
I should also mention that this Inspiron 8200 has an NOS LCD panel which I found on eBay. Very bright and doesn’t have any of the yellowing that you see a lot on old LCDs.
Starting Windows 95. . .
Reply 1353 of 2208, by ShovelKnight
The Model M became progressively shittier as time went by.
The first variant (square badge) is arguably the best.
The next one (oval black badge, still made by IBM themselves) was slightly worse (thinner plastic, thinner backplate, etc.)
The Lexmark variant (blue badge, non-detachable cable) is the second worst. The black badge Model Ms have a nice controller PCB with proper connectors for the membrane contacts. The Lexmark Model M has a very odd PCB and the membrane contacts are simply pressed against contacts on this PCB. If you disassemble it, it's rather difficult to make it work properly again. The plastic and the backplate are even thinner, and at some point in the 90s they switched to single-piece keycaps.
The current Unicomp Model M is the worst. It has the same downsides as the Lexmark Model M, but the case is even thinner and badly molded with lots of sprue, and the backplate is so thin it could be made out of tin cans. They have reintroduced the two-piece keycaps though.
Reply 1354 of 2208, by bjwil1991
I have a Model M released in 1987 that needs a good cleaning on the switches for the arrow keys, but it feels good typing on that thing, and I have a 6' cable that I bought NOS on eBay a while back and it's pretty stellar.
Reply 1356 of 2208, by Caluser2000
Personally don't see what all the keyboard fuss is about. I've had my $25 Genius keyboard for over 20 years now and it's still going strong.
Reply 1357 of 2208, by OldCat
Hey Zack_H, could you elaborate a bit more why this is your favourite XP laptop? Really curious. I have Dell M70, but maybe there's a better fish out there.
Reply 1359 of 2208, by Intel486dx33
Currently my Macintosh Color Classic extreme.
