Reply 180 of 2210, by Tetrium
- l33t++
I decided to take some pics of what my attic currently looks like. It's still a work in progress and theres lots of work to be done (mainly sorting all the stuff I accumulated over the years) but you can already see what it's going to look like when it's done.
I'm done placing the metal storage thingies (yes, blood was spilled 😵 ) and am sorting out all items in a meaningful way so I don't spend half my time looking for stuff and only finding stuff I was looking for 2 weeks ago...while tripping! 😵
First is a pic of what I call the parts corner. Not much has changed yet but most of all the stuff in there is being resorted atm. The stuff on the top is still going to be sorted, it's not going to stay this way.
This will possibly also be the area where I'll keep all paper notes, jumper settings, manual booklets, etc, all in a single spot 😀
***The*pics*are*clickable!!***
And mind you, theres still a lot of stuff on the floor. The attic is still under construction 🤣
Old parts corner
New parts corner
I've done some extensive changes in the mobo corner, mainly adding a lot of extra storage space as most of the stuff was laying on the ground all the time.
I've also added storage for all my floppy stuff, optical drives and harddrives as those were either stored in boxes everywhere or simply laying on the ground getting in my way all the time.
Old mobo corner
New mobo corner
The "media" corner, for stuff that has something to do with the computer word "drive"
The area where I kept my PSU's and some various stuff has doubled it's storage capacity (to the left what was already there, to the right the recently added one). I've planned to keep all my PSU's there (my AT PSU's were, again, basically everywhere) and use that area for miscellaneous stuff also. Part will be used to store extra computer cases (on top as theres plenty room left) and part will be my new "Newly received stuff I haven't cleaned+tested yet" area as everything I received either ended up getting mixed with the already tested stuff or, again, landing on top of some random area where there was still some surface area left.
How it was
How it is
"Computercase row" 😜
Next is my new workbench corner. Still need to sort through all the stuff I hastily put on top of there.
First pic is a pic of the old workbench corner, second one is the new one
The old bench corner used to be nothing but planks I salvaged from old furniture etc and lots of computer cases.
This was impractical though, the planks were simply too small and if I happened to need one of those cases I'd be stuffed 😜
For the new workbench I got another one of those metal storage thingies (what the heck are those storage thingies called in English anyway?? 😕 ) and basically set up 2 halves on top of which I placed an old door hehe 😜
And the newly created storage space beneath the new workbench is where I'll be keeping things like my test hardware, cables, cleaning stuff, adapters, CPU coolers, case fans and that kinda stuff 😉
Old bench corner
New bench corner
I'm kinda doing things as I go along, so not everything is final yet.
Theres still a couple drawer closet thingies to be placed here where I'll be storing small stuff like memory modules and other small things.
And what a long writeup this post was!
At least the clickable pics work, first time I tried it out that way 😁
