My Ultimate VL/EISA 486
Showcase your Retro PC / Build logs.
Re: My Ultimate VL/EISA 486
Postby Anonymous Coward » 2019-6-10 @ 10:34
Cool, it's good to see another SuperEISA in action.
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby bbuchholtz » 2019-7-10 @ 14:22
So, I've finally overcome my learning curve with EISA. I've learned the ways of ECU :)
I have a question about bus mastering. Would you happen to know how many slots on this board support bus mastering? From my perspective, I'm getting conflicting information around slot #8.
In all of the related ECU CFG files, it would seem that only slots #1 - 6 support bus mastering:
Code: Select all
; Configuration file for MCCI EISA system board
; Revision: 1.0
;    10/30/92
;    Modified: (Changed ID to AMI68B1)
BOARD
   ID = "MCC0001"
   NAME = "MCCI-486 EISA System Board"
   MFR = "MCCI"
   CATEGORY = "SYS"
   SLOT = EMB(0)
   READID = YES
SYSTEM
   NONVOLATILE=8192
   AMPERAGE = 26500
   SLOT(1)=EISA
      BUSMASTER=YES
   SLOT(2)=EISA
      BUSMASTER=YES
   SLOT(3)=EISA
      BUSMASTER=YES
   SLOT(4)=EISA
      BUSMASTER=YES
   SLOT(5)=EISA
      BUSMASTER=YES
   SLOT(6)=EISA
      BUSMASTER=YES
   SLOT(7)=EISA
      BUSMASTER=NO
   SLOT(8)=EISA
      BUSMASTER=NO
However, when I look at the motherboard itself, I get the impression that only slot #7 is slave:
Any insight would be greatly appreciated!
-Brian
bbuchholtz
Postby NJRoadfan » 2019-7-10 @ 22:35
I don't think the SiS EISA chipset supports more than 6 slots as busmaster. The reality is most folks don't have that many busmastering EISA cards to begin with so its rarely a problem. Both my Micronics and Tyan (uses SiS chipset too) made the VLB slots non-busmaster since it was likely they would see VLBus cards anyway.
NJRoadfan
Postby bbuchholtz » 2019-7-11 @ 13:24
Thank you for your reply :)
That does make sense. And I agree that having 6 bus mastering slots is probably enough.
This was just my wishful thinking. Most full-length cards take advantage of bus mastering. Slots #7 and 8 have plenty of clearance. Unfortunately, the CPU fan and heatsink prevents the use of full-length cards.
-Brian
bbuchholtz
Postby bbuchholtz » 2019-7-14 @ 17:29
Hey Guys,
Which ECU are you using to manage EISA with this board? So far, I've had the most luck with this one:
http://files.mpoli.fi/unpacked/hardware ... -eisa.lzh/
However, it's not perfect. In particular, I'm trying to add this SCSI host adapter:
http://108.59.254.117/~mR_Slug/EISA/!CPQ4002.CFG/
I'm getting the impression that I should should be using a Compaq ECU with this peripheral. But so far, Compaq's ECU always seems to hang whenever I try saving the EISA settings.
-Brian
bbuchholtz
Postby NJRoadfan » 2019-7-14 @ 18:28
The AMI EISA tool works fine with it. Drop the CFG file for the card you are installing, run the tool, done.
NJRoadfan
Postby bbuchholtz » 2019-7-16 @ 16:52
Ok, I got the AMI EISA CFU working with my system. At first, I was greeted with this message, after saving EISA settings:
Based on my Googling, it would seem that EISA has a limited amount of space for configuration. Long story short, I had too many EISA cards installed. When I pulled some cards out, the error went away and I was able to boot from the HBA.
Onto my second issue... All CFUs fail on parsing this CFG, except for Compaq's:
At first, I was getting complaints about lines 14 and 15:
Code: Select all
 VERSION=1.2AH
 REV=0
These seemed benign; so I commented them out. However, line 45 seems more crucial:
Code: Select all
 RESOURCE="ADDRESS",COMMON,LOCAL
Unfortunately, Compaq's CFU still hangs on my system...
-Brian
bbuchholtz
Postby NJRoadfan » 2019-7-17 @ 23:21
How many cards/what cards are installed? The Shadow RAM error is likely something else. I know the CMOS setup has various shadowing options.
NJRoadfan
Postby bbuchholtz » 2019-7-18 @ 01:57
Currently, I do not have any POST errors. Here is my current configuration:
[SLOT1] Adaptec AHA-2740W (EISA bus master)
[SLOT2] (Empty)
[SLOT3] Diamond Stealth64 4MB (VLB)
[SLOT4] Intel EtherExpress PRO/100 (EISA bus master)
[SLOT5] Adaptec AHA-1542CF/1540CF (16-bit ISA)
[SLOT6] Gravis UltraSound Plug'n'Play (16-bit ISA)
[SLOT7] SIIG High Speed IO-1809 16550 Serial (16-bit ISA)
[SLOT8] (Empty)
Are you suggesting I should try playing around with the Shadow RAM settings in the CMOS?
Thank you again for taking a look!
-Brian
bbuchholtz
Re: My Ultimate 486 (Almost Finished)
Postby Intel486dx33 » 2019-7-18 @ 18:15
Anonymous Coward wrote:It's hard to say how much it cost me, because I've been working on it for 7 years...but probably something like $400.
I'm running PC-DOS 2000 and WFW311.
This is the Nicest computer I have seen in a while.
But it would cost allot more than $400 to build today with the inflation of used computer parts.
What are the benefits of EISA cards over VLB and ISA ?
Intel486dx33
Postby NJRoadfan » 2019-7-18 @ 21:08
bbuchholtz wrote:Currently, I do not have any POST errors. Here is my current configuration:
[SLOT2] (Empty)
[SLOT8] (Empty)
-Brian
That isn't too many cards. Personally I set the entire UMB area along with the usual BIOS/Video BIOS to shadowed and then use the latest version of "The Last Byte Memory Manager" to use the area for loading things HIGH. I have the same Adaptec card and never had a problem with it on that motherboard.
NJRoadfan
Postby Anonymous Coward » 2019-7-23 @ 01:11
EISA over ISA? Multiple busmasters, 33MB/sec vs 5MB/sec bandwidth, 32-bit addressing (no 16MB limitation).
EISA over VLB? Stability, supports way more cards.
EIsA is the way to go if you want wide SCSI and 100MB/sec network controllers. Admittedly, not such a good choice for graphics but you can get boards with both VLB and EISA slots and have the best of both worlds.
Bringing PCI into the equation changes things a bit, as it's much cheaper and easier to get PCI 486 boards. There are a lot of crappy PCI 486 boards though, whereas most of the EISA 486 boards are quite solid.
User avatar
Anonymous Coward
Previous
Return to System Specs
Who is online
Users browsing this forum: No registered users and 5 guests
