Reply 20 of 27, by Thirst
- Newbie
wrote:That card you linked is not even an IDE controller, it's MFM. Those things were obsolete several years before 486s even hit the market. Putting aside the considerable difficulty of finding a working MFM drive, "dramatic" wouldn't even begin to describe the performance hit... that thing would make the machine unusably slow.
You've no idea how glad I am you guys are around 😊
wrote:How much troubleshooting have you done with your existing controller, though? There's any number of things that could cause it not to work, which may or may not be any fault of the card itself.
Well.. the fact that the machine boots and posts just fine with everything but the controller card would suggest that it's that specific bit of hardware that's to blame. I've tried switching to a different VLB slot, taking out everything else except the essentials, disabling every interface on the card by way of the jumper switches, and it still wont work.
With the card inserted the fans will spin and the machine does.. something machine-noise-like, but there's no onscreen action whatsoever.
