How to play ALL games smooth & with perfect sound
Showcase your Retro PC / Build logs.
Postby sNaKe » 2003-10-28 @ 17:18
check my profile for my "brandnew" pc :P :D
sNaKe
Postby Qbix » 2003-10-28 @ 20:32
This belongs in systemspecs
*moving*
Neat system. But I think you can't run all the games :)
especially memory might be a problem for real old games.
Speed also.
I think Bouncing babies is too fast on your pc :)
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Snover » 2003-10-30 @ 01:30
Turbo switches are your friend, Qbix. :)
Snover
Postby Qbix » 2003-10-30 @ 08:47
Ah offcourse :) I tend to forget that these switches existed in the first place.
Was a good idea though. You get 2 cpu speeds for the price of one :)
User avatar
Qbix
DOSBox Author
Postby oldbushie » 2003-11-06 @ 06:47
Now me, I just gave in and bought a Pentium 133. Not bad, $40, though even that is a bit much for some people I suppose. At least everything's in great condition!
I still love DosBox though, I soon as I figure out how to get the sound perfect (still somewhat jittery for me) it will be da bomb.
oldbushie
Postby robertmo » 2003-11-06 @ 08:25
sNaKe: you should consider adding gus and mt-32 to yor pc :)
Qbix: you can also try turning off external, internal or both caches giving you even more cpu speeds for the price of one ;)
oldbushie: i guess your cpu is too slow for dosbox or you have speeded it up too much, you should also play in fullscreen.
User avatar
robertmo
Postby oldbushie » 2003-11-06 @ 08:27
Heh. I'm not running the program on the Pentium 133, but I use it as my last resort for really stubborn games. The computer I have Dosbox on is 1.4 GHz so I don't think it's a speed problem per se (and I have changed around the framerate to no avail).
oldbushie
Return to System Specs
Who is online
Users browsing this forum: imi and 2 guests
