Reply 20 of 23, by sliderider
- l33t++
wrote:But it is not at all the same as a GX1. Completely different machine. […]
If his video is the same as the video in my Dell GX1 machines, then it should be some variant of ATi Rage with it's own dedicated memory.
The variations of the PII/PIII-era Optiplexes I've worked on are roughly as follows... there are some others, but these are the most common:
GXa - 440LX, Rage Pro 2MB/4MB, Slot1, PII only
NX - same as a GXa, but with no externally accessible drive bays
G1 - 440BX, Rage IIc 2MB/4MB, Slot1, no audio
GX1 - 440BX, Rage Pro 4MB/8MB, Slot1, Crystal audio optional
NX1 - same as a GX1, but with no externally accessible drive bays
GX1p - seems to just be a GX1 with ECC memory installed?
GX100 - i810, Intel graphics, S370, no audio, mostly limited to Mendocino Celerons, though some later revisions can be coaxed into taking a PIII, and I've run across a couple that had the same 133fsb-capable board as the GX110
GX110 - i810e, Intel graphics, 133fsb support, Slot1 or S370, ADI audio optional
GX115 - i815e, Intel graphics, 133fsb support, S370, ADI audio
Then a new video card is definitely in order because Intel graphics from back then were sufficient for running apps, but not if you wanted to do any serious gaming. A Voodoo 3 or TNT2 would be the minimum for a machine like that. Hopefully it's not a small form factor model.
