Reply 40 of 42, by infiniteclouds
... and also that the Lo-Tech RAM board can only do EMS OR UMBs but not both. However, given that he doesn't use more than ~43KB for UMBs and 2MB for EMS it sounds like a combination of the 1MB and 2MB EMS boards could accomplish everything the Acculogic does. However, I'm not certain if anyone has tried using two such boards in a system and how it worked.
wrote:SIt's okay though, really - I'm not looking to play Falcon 3.0 or Betrayal at Krondor on this system... 😀
Why not? 😜 Falcon 3.0 has the same requirements as Dune -- which you've already run. Betrayal at Krondor's minimum requirements show 386SX and 2MB RAM -- so you should be able to? I see you said you benchmarked at 7.4FPS in 3DBench. Based on our VGA benchmark database that's about a 386 SX @ 25mhz w/o a co-processor. That is pretty incredible for an XT machine. Does your I-O PK-X486S upgrade have an integrated mathco?
