First post, by luckybob
- l33t
This morning (actually yesterday) my gaming router decided that 5 years of demanding service was enough. (D-ling DG-4100) I do feel sorry for it, the thought of the literally countless packets of data it handled...
anyway, as I don't have the cash for a new one, I tethered my phone and downloaded smoothwall to turn one of my computers into a router. I had wanted to do this for quite some time actually. In the back of my mind, I was secretly hoping google would come do Denver with their gigabit internet and I would need some super computer as a router. It would seem that fate has conspired to force my hand.
Now, the 'target' of this project was to be 2 p3 tualatins on an he-sl chipset motherboard. Since I don't have one yet, I decided on the next best thing. My dual slot 2 xeon!
getting it up and running was easy enough. sortof. Something is still not quite right, but if I finger it a little more it should be fine. I shouldn't have to manually tell my router to allow access to the internet right?
anyway here are 3 pictures of the new router:
I have NO idea why I put my router into a $100 lian-li case. Especially considering its going to spend its life in a dark basement and I wont be looking at it. That said, its an Asus XG-DLS ( 440GX dual slot 2) With TWO 900mhz Pentium 3 xeon processors (2mb cache each) And if that wasnt enough I dropped in 2gb of ram @ cas2 I was going to put a 10k rpm scsi hard drive in it, but decided against it. It will probably NEVER write to the drive more than once a day so it would just be a noise/heat generator. So instead I slapped a 2gb compact flash card in it. If I ever find a he-sl based dual tualatin, I will probably use it to replace these black monoliths, but I haven't seen a suitable board for a long time.
Side note, I pulled my dual 2800+/voodoo 5 out of this case, I had been using the system as a garage music box/gaming for quite a while. It had gotten a little unstable, and I felt a re-build would help. It turns out the motherboard is going to need a re-capping.
Damn teapo pieces of shit...
*sigh*
edit: It does just fine maxing out my connection downloading 5 different torrents at once:
