First post, by Nahkri
- Member
This is my third and probably last retro build.
Motherboard:Gigabyte BX-2000 ,intel 440bx chipset
Good things about this mainboard:dual bios,support for 133 mhz fsb,multiplier settings up to 9.5.
Bad thing:voltage auto sets itself depending on the processor used,no way to increase or decrease voltage.
There is 1 jumper on the mainboard,i,m not sure what it does,the manual describes it as system acceleration and i have 2 options:100mhz normal(default position) and 100mhz turbo and other frequencies.
Processor :Intel Pentium III 450 mhz,with stock cooling,i wanted a P II 450,but this is closest i could get.
Videocard:Msi manufactured Nvidia TnT 2 Pro 32mb
System has 348 mb sdram pc133,Western Digital 40gb 7200rpm 2mb cache hard drive,a temporary isa soundcard Labway with ymf 719-s(i will replace it as soon as i can find a cheap Live or Vortex 2),floppy drive ,Toshiba dvd rom ,450w power supply.
After 2 AT builds,it was nice to work with a ATX case,much more space to move around.
The case is a second hand 1,but in good condition,was lucky that a unused backplate i had perfectly matched the mainboard.
I noticed that the cpu 3D mark of the p III at 450 MHZ is lower then my K6-2+ at 550 MHZ
