First post, by GeorgeMan
- Oldbie
After Skyscraper showed his slot1 baby-AT build here Slot-1 Baby-AT Minitower build., my case complained and I decided to show it too! 🤣
Purpose? Late 90s gaming of course!
3dfx voodoo3 3000 obtained from keropi and PcPartner VIB862D baby-AT slot1 mobo obtained from sprcorreia. The PSU is brand new, the CPU is a PIII 750 (7.5x100) Coppermine with massive-passive heatsink attached!
View from above without the PSU:
After a couple of minutes the Voodoo3 gets EXTREMELY hot (typical, but I didn't feel good with that), so I decided to put a fan. Why a big one? To cool the CPU and the GPU together, silently! 😉
Case front. A little yellowing but I don't have another AT case 😢
More photos of my desk can be found here: post up pics of your "computing area"
And if you want more info on the home made LED MHz indicator, go here: Creating a new LED MHz indicator for my PC's front panel! [PROJECT]
TODO list:
- Waiting for a PCI -> USB card, as just one onboard USB is not handy...
- Need to cover 1 slot on the back of the case and the COM/LPT holes.
- Need a new PS/2 bracket and cable because this one has also an LPT hole. But where can I find one...? 😕
What do you think? Any suggestions for making it better please? 😊
Specs right behind --> Monitor is Hitachi 19" CM772E "flat" from 2001 (1800x1350@75Ηz max, 1600x1200/1280x1024 @ 85Hz) 😉
Retro1: Athlon XP 3200+ @Arctic cooler | ASUS A7V600 | Radeon 9800XXL 128MB | SB Audigy 2 ZS | 160GB IDE HDD | Win98SE & XP
Retro2: under construction with a PIII 933 or a Tualatin Celeron 1200 and a GF2 GTS 32MB
