The Uber Dell Project (P4 Northwood)
Reply 20 of 24, by Darkman
well , on the one hand that machine is overkill , my last machine was a Phenom II and it was enough to run Max Payne 3 above 60fps , let alone something like Doom 3 or Oblivion.
then again , Im doing the same in regards to XP at the moment, so I can't fault that logic.
Reply 21 of 24, by maximus
Quake III Arena 1.32, demo four
1024x768, 32-bit color, maximum settings
199.1 - no AA, no AF
182.1 - 2x AF
162.1 - 4x AF
148.2 - 8x AF
158.3 - 2x AA
109.6 - 4x AA
50.2 - 8x AA
96.2 - 4x AA, 8x AF
All done with Windows XP SP3 and ForceWare 93.71.
PCGames9505
Reply 23 of 24, by Mau1wurf1977
What chipset do these Dell P4 motherboards use? Are the PSU connectors standard?
Does anyone have documentation / list of part numbers, versions and board specifications?
I had good experiences with two Acer Tualatin S370 boards. Extremely stable and easy to work with. So OEM boards could be of interest to some.
My YouTube channel
Reply 24 of 24, by maximus
The Dimension 4500 motherboard uses the Intel i845E chipset. The PSU connectors are standard, but the 3-pin fan header is not. The BIOS are neutered, and, as shamino stated, the CPU temperature can't be read by Coretemp and the like. Otherwise it's a perfectly good board. Very stable in my experience.
PCGames9505
