PcBytes wrote:A idea: […]
A idea:
-ABIT VT7 motherboard (socket 478,VIA PT880 chipset,DDR400 and obiviously AGP 8x & 2x SATA)
-Intel Pentium 4 3.0GHz with HT (a Prescott will do wonders)
-320 or 500GB HDDs (as long as they support SATA150 mode)
-Windows 7 SP1 or Vista SP2 (SP2 is closer in performance to 7)
-Sound Blaster Live! or Audigy
-Delux MG760-BMW or Lian Li PC-S80
-your choice on video,but mine would be HD3450 AGP would be good. FX5500 if you want retro.
-FSP BlueStorm II 400W - it's going to draw some power,mainly the video card would draw some power
-512-1GB RAM - 512 for Vista and 1GB of RAM for 7.
I love it. I had a VT7 back in the day - was a great performer, and overclocked fairly well too. 😀
As far as the build overall:
- FX 5900 is completely out of the question for 2006. It was inadequate by 2004 for heavy DX9 games like Half-Life 2 and other games, because of it's poor shader performance. For games like Oblivion, Hitman 4, etc it will be a slideshow. You could probably struggle-by with a Radeon 9, but really you want something much faster for games like Hitman 4 or Company of Heroes etc if you want high IQ settings. If you're fine playing at 800x600 with relatively low settings that's another story altogether (but the FX 5900 is still a bad option).
- AthlonXP is also out of the question; no SSE2/3 and that *will* hit you in games from 2005-onwards like Hitman 4, Oblivion, FEAR, etc.
My broad suggestions if you're going 2006-ish as your top-end and want to stay with hardware that's actually from that era:
- Athlon64 X2 or Pentium D
- GeForce 7800/7900/8600/8800 or Radeon X1800/1900 or 2900; multi-GPU at your option
- 1-3GB of RAM
- SB Audigy or X-Fi
- At least 600W PSU
The cheapest route is probably a Pentium D and a Radeon HD 2900 (they're under $30 on ebay these days, and will outperform the X1800/1900 cards that cost the same). But that will require fairly considerable power supply, especially if you want 2-3 GPUs (you're talking 700-1000W PSU now). Of course the VT7 route would be great too, just stick a 6800 GT/Ultra, 7800GS AGP, or X1k AGP in there and it should handle itself very well at lower resolutions. 😀
If you wanted to go really nuts, get an Intel 975X, Pentium D Extreme Edition, 2-3GB of DDR2 in dual-channel, a pair of Radeon HD 2900XTs, and an X-Fi. It should handle everything from the mid-2000s with no trouble. It will require *a lot* of power though.
If you want to do 2003, that's another story altogether - a high end AthlonXP with a GeForce FX or Radeon 9 is bang-on. Pentium 4 also works, but if you already have the XP go with that. 😀 If it helps any, my '03 box is setup like this:
- 2x Xeon 2.8GHz HT
- Intel 875p based Asus PC-DL
- 2GB DDR
- Audigy 2 ZS
- GeForce FX 5800 Ultra (swapping to a 6800 Ultra did very little for 3DMark01 score and has no appreciable difference for most games it runs; most of which can't even get the 5800 to spin up to full-speed)
It handles DirectX 7/8 and some early DX9 games very well - we're talking about games like Empire Earth, ORB, Morrowind, Halo PC, UT2004, etc. It can probably run the first 2 or 3 Hitman games pretty well, I just haven't tested them out yet. 😊
There was a lot of stuff that changed between '03 and '06 - DirectX 9 really took off, Vista was released, DX10 came about, memory got cheaper, and so forth. Compatibility didn't really break though - all of the games that my '03 box can run, would run fine on a Windows XP computer from 2006-7 as well. The only thing I wouldn't touch is the Audigy or X-Fi (and I prefer Audigy because the drivers are simpler to setup); they'll work well for all of the later DirectSound games, they both do EAX, etc. 😎
