Reply 40 of 49, by Tali
- Member
Is that Antec Three Hundred I spy in this build? Loved that case, it used to house Assassin before I moved it into Define R6... and long before it was called that. Brings back memories... Come to think of it, it was the first case I used that wasn't an El Cheapo, and wouldn't house El Cheapo components.
There was one other expensive system before it, actually similar to your build: a 440GX-based Dell PowerEdge 2300. I used to love that thing, it had dual Slot 1, 1Gb of Registered RAM, SCSI with hot plug and all that nice server goodness. But it was "backwards". The board was at the opposite. Good old Dell, compatibility is our Nr. 1 priority. Ruining it, that is. And it didn't have AGP. Who needs that on a server, right? Still, with 1 GHz P3 and a PCI version of GeForce 6200, it would run Lineage II... to an extent. Now I'm sad it went the same way many of my older systems did... and, given how enormous and heavy it was, I doubt anyone picked it up either.
