IBM PS/2 286
First post, by nemesis
I was recently given this unit from a friend. He kept it in excellent condition, but decided that it was no longer suiting his needs for computing.
It's an IBM PS/2 Model 30 286 10 MHz Intel CPU.
I haven't double checked the RAM, but I think it was 1 MB.
The RTC needs to be replaced, and the 1.44 proprietary floppy drive doesn't seem to read diskettes.
I have a 2.88 MB floppy drive, that I'm hoping will work and am in the process of changing it.
This is some of the software that I got with it. Not bad for free.
Reply 1 of 17, by Sutekh94
Nice pickup! Seeing as that particular PS/2 doesn't have Micro Channel slots, I'd recommend tossing something like an SB 1.5 in it. Also, I'd recommend trying to clean the 1.44MB floppy drive.
My YouTube | My DeviantArt
Reply 2 of 17, by tayyare
nemesis wrote:
.... but decided that it was no longer suiting his needs for computing.....It's an IBM PS/2 Model 30 286 10 MHz Intel CPU.....
Quite surprising!.. 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 3 of 17, by vetz
My first computer! So many memories from the Model 30!
Played Wolfenstein3D (lagged badly), Stunts (lagged badly), Simcity, A-train, Links World Class Leaderboard, Mechwarrior 1 (lagged badly!) among other games on it.
It was retired to junk when we moved in 1998 🙁
Reply 4 of 17, by luckybob
is that a BOXED copy of dos 4.0? I dont think that was a very common version!
Also, I love these IBM's! I have several, so if you have any questions i'd be happy to help.
Reply 5 of 17, by chinny22
The mouse, the screen, I love how everything is period correct.
I may be wrong but I think IBM is PC Dos not MS Dos
Reply 7 of 17, by mav85ale
beautiful! My friend had a 386Sx with the same case 😀
Olivetti M290 / 386SX 16MHz / 4MB / 100MB HDD / TSENG ET3000 / Opti 82c931
Commodore 486DX33C / 486DX2 66MHz / 8MB / 500MB HDD / WD90c30 / Vibra16
Pentium MMX 233MHz / 64MB / 8.4GB HDD / Millennium II 4MB / 3Dfx Voodoo / Creative SoundBlaster AWE64 GOLD
Reply 8 of 17, by nemesis
I actually was starting to go through my ISA soundcard collection to see what I had along those lines, Sutekh94. Good idea.
I might actually need some advice on the 1.44 Floppy drive from luckybob or anyone else that knows about this stuff. I pulled the 1.44 drive and replaced it with the aforementioned 2.88 IBM Floppy (which at the very least works with 1.44 disks, but I can't seem to find my 2.88 disks to test it's limits), but when I touched the 1.44 drive, I noted that there was some kind of an oily substance on the bottom. I quickly checked to see if it had leaked anywhere else in the case, but it seemed to only be on the bottom and side of the drive. Any thoughts as to what that might be, or if that might have had anything to do with it ceasing to work?
Also, that is in fact, a boxed copy of IBM DOS 4.0. Not Microsoft.
I have always loved these classic machines, and I've always had a thing for running software on them that's technically not supposed to work (usually results in slideshows).
I'm sorry that yours was junked. That was a tremendous waste of beautiful computing. I've seen my fair share of items go to waste when I was younger and folks didn't know the future value of said items.
The 386SX is the IBM Model 55SX @ 16MHz, iirc.
A little backstory to the whole thing: My friend has been using this machine since 1988 (If I understand correctly) to archive stuff for the church. When the RTC went, he decided that it would be too much of a risk to replace it (he really isn't a computer guy), and upgraded to a newer system. That was about 3 or 4 years ago. He continued to play games on it, and I enjoyed a few hours of gaming on it at his house, myself. So he decided that this near-mint machine should go to someone that would appreciate it... me! 😁
Reply 9 of 17, by nemesis
Another question: I noticed that the Clock Crystal Oscillator near the CPU is rated at 48 MHz. Does this mean that the system could potentially support a 20 MHz CPU, or am I completely misunderstanding the concept?
Reply 10 of 17, by luckybob
No, thats for something else. Video probably.
As for the floppy drives, i'd clean it up with alcohol as best as possible. if that doesnt work, the drive probably needs new caps. This is actually pretty common, especially in the Alps drives.
If you have the time, could i get an image of those dos 4.0 disks? I dont have a good 4.0 version.
Reply 11 of 17, by nemesis
Thank you. I found my 91% isopropyl alcohol, and I'll be putting that to use soon.
I looked closer and found a Clock Crystal Oscillator rated for 20 MHz. Pretty sure that's the one for the 10 MHz CPU.
I'm having some trouble getting the drive images, so bear with me. How would you like them delivered, after I get them?
EDIT: I have not found any spare sound cards that are suited for this machine. Which is OK for now. I kinda like the PC speaker with certain vintage games. 😀
Reply 12 of 17, by i386
If is it possible I also would like to receive MSDOS 4.00 disks after you get them, please.
I have 720K disks for Microsoft DOS 4.01 version, but I havn't normal 4.00 version.
For case, If anyone interest 4.01 MSDOS images, I attached 4.01 images.
MSDOS 4.xx has very quirky installation program. You will need a blank disk to install it.
    MSDOS4_01.ZIP
    954.3 KiB
    79 downloads
Reply 13 of 17, by luckybob
here are the images i got from nemesis:
MS DOS 4.0 IBM.7z
442.45 KiB
80 downloads
Reply 15 of 17, by Caluser2000
IBM Dos 4.xxis the same. It'll copy the operating system installation from the original disks to blank disks and you carry out the installation from those.
Reply 16 of 17, by solifer82
I know that this is an old topic, but I'm sure there's someone wondering the same issue with the Dallas battery and the diskette drive. I have two of these machines, and both had problems reading the diskette when the battery was dead. After modifying the Dallas, everything worked fine, so there's probably nothing wrong with the diskette drive in this case.
