Reply 20 of 21, by Matth79
If that 1.2G Athlon is a "B", then you're good - if it's a "C" then you'll only get 900MHz out of it, at bit more if you overclock.
The KT133 chipset sounds like it ought to do 133, but it was flawed - KT133A is needed for 133FSB - the KT133 can hit 110FSB overclocked, maybe 120 if you're lucky.
I had a similarly limited AMD Irongate chipset
