First post, by T4600C
- Newbie
After reading the jumper manual, this is how far I got with a chip that ran at 75Mhz
Looking at the CPU model, do you think that I could push it further? no idea.
Also, do the clock and bus speed jumpers on the Compaq motherboard put a higher voltage on the 3.3v CPU? or do they increase the speed in a different way? I wouldn't like to overclock a Pentium CPU with higher voltages if that is what I am doing.
Cheers,
Niels
