Artex wrote:Don't you just love it when stuff like that happens? Excellent news darksheer!
Thanks 😊 That was totally unexpected I felt so lucky to found this forgotten pc and make it run like it was new hardware 🤣
Dreamer_of_the_past wrote:This probably it Re: XP SP2 vs XP SP3? Which one is faster? […]
Stiletto wrote:I'm sure there's a thread about SP2 vs. SP3, lost to the ages here on VOGONS. 😁
mr_bigmouth_502 wrote:I once had a Pentium 4 box that ran quite nicely with just SP2, but I was purposefully keeping it offline due to the potential security vulnerabilities. It slowed down to crap once I installed SP3 and put it online. 😜
We definitely need some benchmarks...
On a fresh install of Windows SP3 and tuned as it should the system is super reactive (fast boot, and for both games and exploring/playing files tasks...).
The only thing that is not as fast as the rest is When you use a recent web browser with flash player installed, I think the service pack used is pointless in compairison.
It's so cpu intensive and memory hungry that it should put a P4 3Ghz HT on its knee without much effort and I don't think it would be faster using SP2.
Sure I can play SD youtube videos without a problem but HD should be a bit problematic and even more whem you only have 1 GB or less of ram at disposal.
The 3DMark2003 score I obtained is even faster than those with identical hardware (with same stock frequencies) back then when SP3 wasn't out.
It's true that the video driver is not actually the same but I don't think this alone would make a +- 500 points difference on a 8200 score.
