First post, by Jolaes76
Up till recently, I was not particularly excited about building such a slow retro rig before, but now that I had an excellent base for free, I thought I would give it a chance.
I don't post regularly about my builds and experiments either, but this last one proved quite a challenge... so I thought I make a few photos as this thing actually works. Thanks goes to Carlostex, Alexanrs, Great Hierophant, Anonymous Coward here and Trixter and other veteran members of VCF for their informative posts and the inspiration.
Special thanks to keropi for sharing his XT-IDE BIOS build (man, what an ordeal was to find out the double bit swap at the end of the binary file for 3c503 compatibility 😀
Well, it befell that shortly before last Xmas I received a gift - a new-old-stock XT clone motherboard...
As a teenager, I worked and played around with 286s but never used XTs (though I met them in rundown offices, already being already phased out, these strange looking Methuselahs...)
This present was a modest 256 kb board, so I had to order the necessary memory chips (two different types!) to get that whopping 640 kb. Smooth sailing so far.
Then I run through my oldest boxes and found some cards: a Hercules, a CGA and two EGA cards (but I do not have such monitors) and an 8 bit Intel VGA (pictured) plus over a dozen Trident 8900s which I knew would work (from VCF forum).
I also found a 40 mb NEC MFM HDD on a 16 bit WD controller, and 3 8bit MFM controllers that can drive the NEC although not at full capacity.
After some thinking and considering the cometing price of MFM stuff, I dropped the idea of using real spinners as storage and settled with an XT-IDE Bios in a NIC + CF-cards solution.
The baby AT tower case is currently under RetroBright treatment...
More pics coming soon.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
