Tetrium wrote:You used a Pentium 1 heatsink?
These were so very common in mostly OEM systems, but I find the thickness of the bottom of the he […]
Jade Falcon wrote:Here what the system as of now.
These were so very common in mostly OEM systems, but I find the thickness of the bottom of the heatsink (the part were all those spikes attached to, dunno how to correctly name it in English) kinda lacking.
I've always wondered what use I could give those.
Well no, I pulled that off a 6 or 700mhz something c3. Should do ok with all the case fans I have.
That's 2 120mm 2 60mm 2 80mm and 1 92mm.
I also got a seasonic psu with a 120mm fan in it I'll put into the system. It ever has a 30amp 5v rail!
I might use something different, but I like the idea of keeping it passive.
EDIT:
Well this sucks. I can't up the multi past 8. But if I set it to auto it will go to 9.
I can't seem to find away to change the multi in the bios. But I can change the fsb from 66mhz all the way up to 166mhz.
Maybe a bios update will fix that???
I may lower the mutli via the motherboards dip witches and set the fsb to 160-166. That should get me some good top end performance. 160x7.5 should be good. I could dump the fsb down to 66mhz and disable l2 for dos.
As for the heat sink. It bealy gets warm at 1.65v. So if I can keep the voltage at 1.45v it should do grate. But I have room to oc if need be.
