First post, by Paadam
- Member
I am not a biggest fan of Netburst architecture but got MSI MS-9121 system board for 5 euros that originally came from IBM Intellistation Z Pro and since I already had IBM eServer case, I thought I'd give it a go. All the IBM proprietary front panel connectors were plug and play with the case.
Board needed a recap (11 of the caps were bulged, none of them were CPU supply ones) and even then the board POSTed up nicely. I also got 2x Xeon 3.06 GHz (512kb L2, 1MB L3) and 4x 1GB RAM with it plus a pair of beefy copper Xeon heatsinks.
Originally the board had Ati RageXL 8MB video in its miniPCI slot but I removed that and put Intel 2915ABG wireless card in it. Fortunately there was no wihtelist or something like it is on Thinkpads (and other brand laptopts) and the computer is really usable with this. Used 7600GT AGP with Zalman copper cooler, 3DMark2001SE was ~18300 points. Running WinXP.
I will get some tested 73GB SCSI drives soon and will replace the ATA drive in it. Also found Aureal Vortex 2 that will replace the crappy onboard audio. Already found a pair of nice and quiet Arctic Cooling fans for CPU's, at the moment there are some random ones. After all that it's cable management time 😀
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
