First post, by xjas
A while ago I bought this cute little SE/30 for cheap. I knew it was going to be a resto project and probably didn't work as-is, but I had my hopes up for it. I've never had a compact Mac and damnit, it's an SE/30, so it'd be worth a little elbow grease.
EDIT: Sigh... Broken Photob*cket images removed to avoid showing their stupid ad banner & giving them any more undeserved exposure. Sorry about that. Still zapping these as I find them in 2018.
Well, I finally made the appropriate tool...
[image removed]
...and opened it up. Unfortunately the prognosis is not good. 🙁
Here is what I found:
[images removed]
Already not looking happy. It had been sitting in the previous owner's garage for years on a concrete floor so I was hoping the corrosion was just due to moisture. Pulled the board, and...
[images removed]
Boom. Nope.
[images removed]
I don't think there's a lot of salvageable parts there. The RAM still looks OK but who knows. I'm guessing this thing will never run again. Even if I got a new logic board, which I don't expect will be easy to find on my island, I don't know if anything else like the CRT or HDD/floppy even work. Sadly I think this one, in its original incarnation, is a goner.
What can I use to clean up the capacitor goo from the motherboard so I can at least assess it or pull chips without it being a biohazard? Should I soak it in vinegar or soapy water?
So what do I do with it now? I'm tempted to rip out everything I can and put something like a Raspberry Pi or even the guts of a Mac Mini in there. Or maybe a Techmoan-style Dockintosh.
Is there any way to drive the CRT with a more conventional computer? I don't suppose it accepts a VGA-ish signal.
[image removed - sorry 🙁 ]
Reply 1 of 9, by feipoa
Is the extent of that damage due just to leaving it on a garage floor? Or did this guy's car leak various fluids all over it? The concentration around the battery implies to me that the battery was much of the culprit. I am surprised that the capacitors on that board hadn't leaked yet. My SE/30's caps leaked a few years ago making a big mess.
Reply 2 of 9, by xjas
There is a capacitor there - C12 - that exploded. A lot. :p
Reply 3 of 9, by feipoa
I must be hard of seeing because I don't see C12 anywhere. But I was referring to the smaller silver topped caps.
Reply 4 of 9, by xjas
The remains of C12 are right up there between the battery and the PDS, next to the ROM SIMM. It's kinda hard to see in a 2D photo, it looks like a scorched cinnamon bun. 😜 The silver caps look better in the photos than they actually are, a couple are really dodgy but yeah, most of them are surprisingly intact.
Reply 5 of 9, by Rawrl
Nah, it wasn't a cap that did that; those old Maxell PRAM batteries like to puke their guts out if they're left in storage too long. I have an SE that did the same thing.
The surface mount electrolytics in SE/30s do leak, but they wouldn't cause anywhere near that much damage.
Reply 6 of 9, by Unknown_K
Yes, caps do leak. I just recapped a SE30 board for somebody and there was green corrosion on pins and one pad was eaten away. Thankfully it is 100% working and even looks nice.
The attachment se30_recapped.jpg is no longer available
Reply 7 of 9, by feipoa
I couldn't get my SE/30 working last I pulled it out. It is showing symptoms similar to problems with the analogue board, but replacing the analogue board didn't fix it. The replacement could have been bad too though. I don't know you people keep these things working. Did you find a new replacement part for the flyback transformer?
Reply 8 of 9, by xjas
Here's what the board looks like after some attempt at clean-up. Sadly, I'm calling time-of-death. The battery holder disintegrated when I pushed on it. Some of the pins of the video ROM were so brittle they broke when I tried to remove it and UJ3 & UJ4 just came off in my hand.
[edit: image removed]
There are some decent parts in this thing that are still in good shape, like the RAM & ethernet card, so maybe bits of it can live on to save another SE/30. Looks increasingly like mine is gonna be a case-mod project if I can find the time. I've got something vaguely in mind to do with it.
Reply 9 of 9, by WolverineDK
Well, since you mentioned the Ipad docking mod. I thought about an old hack I saw about that certain machine.
http://spritesmods.com/?art=macsearm
