First post, by Pasi123
SPECS
CPU: Intel Pentium 3 866MHz
Motherboard: Asus CUSL2-C
RAM: 512MB RAM (2x256mb)
Graphics: 3Dfx Voodoo 3 2000 16MB
Sound: Don't have yet
Hard Drive: Don't have yet
Case: Don't have yet
OS: Windows 2000, 98SE or ME
4.53 MiB
1.44 MiB
X5670 @ 4.4GHz|P6X58D-E|24GB DDR3|GTX 960|750 EVO 250GB|4TB, 2x2Tb HDDs|Define R5|Win7
P4 HT 3.0GHz|GA-8SGXLFS|2GB DDR1|9800 Pro|2x 40GB Seagate|WinXP
Celeron 333MHz|Diamond Micronics C400|384MB RAM|Diamond Viper V550|6GB HDD|WinME
Reply 1 of 3, by Tetrium
Hi 😀
It's a good start!
Your CPU HSF seems like a nice one to use for Tualatins and the other s370 CPUs with IHS.
It looks fairly large, I ran into a 'slight' problem with a large CPU cooler and a Coppermine 800 or 866 (very similar to yours) as the very large HSF would (for whatever reason) sometimes stop making good contact with the CPU. Resetting the CPU HSF fixed it for a while till it would happen again.
Replacing that very large CPU HSF with a smaller one ended up fixing this odd boot problem with this rig.
Good luck with completing your build, and have fun 😀
Btw, what PSU are you gonna be using? WinXP will run a bit slow, unless you run an earlier and/or tweaked version of XP.
ME would run nicely on such a rig.
My retro rigs (old topic)
Report spammers here!
Reply 2 of 3, by Pasi123
Tetrium wrote:
Hi :) […]
Hi 😀
It's a good start!
I wasn't able to find any S370 cooler so I borrowed that cooler from a Socket A system. 😁 It have pretty good contact but I will change it if I can find something better.
And for PSU I will propably use a Enlight HPC-300-202.
Reply 3 of 3, by Tetrium
The cooler is actually really good for a Coppermine. If you don't run into any problems, you might as well leave it as is 😀
I also like your (yet uncompleted) rig because it's not just maxed everywhere, I assume you kinda put it together with what you had laying around?
Or did you really plan it this way?
