First post, by hiroshima
Hello vogoners,
I'm planning a new build around an Intel 430hx chipset, not strictly period correct and I need some advises on soundcards.
My target with this build is mid-to-late DOS era and early Windows 95/98 era games.
Main components will be:
ATX class PSU/Cabinet;
Intel Pentium/MMX, min. 133 max. 200 MHz;
Intel TC430HX Tucson MoBo;
64Mb EDO RAM;
As per video cards, I have some alternatives, from a Diamond Stealth 64 Graphics 2001 with an ARK2000PV chipset to a Diamond Viper v330;
Additional 3D card: Canopus Pure3D;
Additional 3D card: Matrox M3D;
Adaptec 2940UW w/ a first generation Seagate Cheetah ST34501W 4.5Gb 10k RPM (alternative: DPT PM1554U2 w/ two Fujitsu MAB3091SP 9.1Gb 7.2k RPM RAID0 😁)
Pretty recent Toshiba DVD-ROM;
Dual sound card setup consisting of a Turtle Beach Tropez w/ RAM upgrade and a Creative Sound Blaster AWE64 Gold w/ SIMMCONN and 28Mb RAM; one card will be connected to a Roland SC-55mkII and a Korg NX5R w/ a Yamaha DB51XG.
An alternative would be a single sound card solution using an AWE32 CT2760 which is already installed in a 486 class machine alongside a GUS MAX and a Roland MPU-401/AT.
What do you think about the audio setup strategy?
Cheers,
Mauro
My system
Reply 1 of 19, by Jorpho
I guess if you're planning to play games that will make use of that sound hardware and you have the money to spend on it and the time to track it down, then you might as well. But I can't really see getting much use out of it.
Reply 3 of 19, by Jorpho
What is the doubt? Consider the games you want to play and whether they can make use of the hardware. Then decide accordingly.
If you're not going to be playing anything, and these boxes are just going to go collect dust in a corner somewhere, then there is no doubt.
Reply 4 of 19, by hiroshima
Well,
You are not completely wrong.
With this machine, the target is late DOS early Windows 3D era, but I wish to put together a 'do-it-for-all' config.
I already have two builds for earlier games, namely a low end 386DX and a fast DX4 machine.
A CT2760 (which is inside the DX4 pc) will provide OPL3 and AWE synthesis in one card, so I planned to use the TB with OPL3 and the AWE64G as a viable alternative.
M.
My system
Reply 5 of 19, by lvader
Any reason you ruled out the 233 MMX? It has many advantages , lower voltage/heat, easily underclocked, supports TR12 options in SETMUL for smooth slowdown. Re sound card options I have an AWE 64 gold in my Pentium build which I'have been very happy with apart from FM, So I have changed the FM io address on the AWE so it doesn't play and I've added a Sound blaster pro 2 connected to the AWE's line in to replace the FM. The combo works great,I just point games to the AWEs address/ IRQ.
Reply 6 of 19, by hiroshima
Hi,
That's exactly what I want to do with the dual sound card solution, FM synth through the OPL3 equipped Turtle Beach and E-MU8000 synthesis via the AWE64G.
Initially I ruled out the P233MMX beacause of known speed related issues but, actually, I didn't know that Setmul supports this CPU.
M.
My system
Reply 7 of 19, by clueless1
You've been given some good feedback already on the sound card front. I'd add on the video card front that the ARK2000PV is both extremely rare and the fastest period-correct DOS chipset ever made. I would pair that with the Canopus, and definitely pick the 233MMX to maximize the Voodoo performance. As lvader alluded, setmul can get that CPU down to fast 386 speeds, so you'd have almost the perfect time machine that will cover games from around 1990 to 1997. He (lvader) just posted some benchmark results of his 233MMX with setmul in the cache disabled thread in my signature.
RAID0 might be risky and overkill, but as long as you have good backups, it'd be too tempting not to try. 😉
Reply 8 of 19, by gdjacobs
If you have a case with a turbo switch, you can wire it up for two different multipliers and change with a reboot.
Switching between 1-2 and 2-3 on J10C1-D would provide a slow and fast multiplier mode (1.5x is 3.5x on a PMMX).
Reply 9 of 19, by hiroshima
Hi,
Unfortunately I'm using a cabinet without turbo button, it doesn't even come with a reset button..
Setmul in combination with different FSB/multiplier settings will do the trick.
@clueless1
I'm surely going to use the Ark based Diamond Stealth64 in this machine. I never used such a graphic card but benchmark results are pretty self explanatory.
For the RAID, actually I'm not very sure that Windows 98 SE has support built-in for the DPT SCSI controller and I think a single Cheetah is just enough 😀
M.
M.
My system
Reply 10 of 19, by gdjacobs
hiroshima wrote:
Hi,
Unfortunate about the turbo button, but you're going to need some method of changing multiplier or FSB should you choose to have that feature. You can always add the required switch to a drive bay blanking plate.
Reply 12 of 19, by hiroshima
Hi Ivader,
I already seen that interesting solution in one of Philscomputerlab YT vid.
Anyway, I am a bit curious about your build.
I can see 4 audio card, a vga and a CF adapter, isn't it?
M.
My system
Reply 15 of 19, by lvader
Thanks!
The case is an Antec GX200 case from last year. I was looking for a compact full ATX case that could fit the monster size LAPCI, and basically this is pretty much the only one I could find. I really like the case.
Each of the sound cards has a role in the build, the LAPCI for early LA synthesis midi games (MT32), the RAP-10 for General midi support with a genuine Sound Canvas sound. I could replace it with a SCC1 which I also own but don't feel the need. The AWE is for digital sound and the sb pro 2 for FM sound. So far they all seem to coexist perfectly.
The motherboard is an Asus TXP4-X 430TX ATX socket 7 motherboard. I was originally going the K6 III+ route but finally chose to go with a Pentium 233 MMX after testing it with setmul as it gave me access to all the speed variations I was looking for I.e Wing Commander I to Quake II and anything is in-between.
Video card is a Voodoo 3 2000 PCI, mainly chosen for its DOS speed and compatibility and great image quality rather then what it does with 3D.
The PSU it quite unusual , it's a fanless Silentmax 350W PSU, also supports the -5V needed by the LAPCI. With the P233MMX also passively cooled, the PC is virtually silent with just a slow running 120mm fan at the rear making any noise.
Reply 18 of 19, by elod
lvader wrote:
The PSU is high-end German made, very solid.
If it's anything like the one in this review than it's really not solid (page 2 has some (few) pictures):
http://www.silentpcreview.com/article90-page4.html
http://www.silentpcreview.com/article90-page2.html
Reply 19 of 19, by lvader
The review calls it solid, they have some concerns over operation when at full load and when no case fan is used. It's worth noting that many is these where put in HTPCs that were mounted in racks with no ventilation. In my case its no were near full load and in a largish case with sufficient ventilation, both inside and out.I have had this PSU from new and have no concerns with it, it runs cool and is very stable. Important for me, it supports -5V. I also own the newer revision of the PSU (mentioned in the review but not tested) which may be significant.
