Post modern Retro FX-60 build Log
Showcase your Retro PC / Build logs.
Postby x0zm_ » 2017-8-10 @ 16:29
Oh man, I had that motherboard back in the day. My housemate did too along with a few other people I know IIRC. It was a pretty popular board around here. Well priced with a good feature set, plus Fatal1ty himself was still a fairly well known name at that point in time.
Mine was running an Athlon 64 X2 5400+ and two Gigabyte 7600GT's in SLI. What a mess SLI was back then.
Hope the build goes well for you
User avatar
x0zm_
Re: Post modern Retro FX-60 build Log
Postby Jade Falcon » 2017-8-11 @ 00:52
Well it was raining out today, so no more mods on the case for now.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-11 @ 21:05
Got a few parts today. The psu, video cards, cpu, and sli bridge.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-14 @ 13:20
Last of the parts should get here today. If so I'll finish the build tonight.
I also added more info/photos of the case/video cards.
The red PCB and blue heat sinks go well together.
Jade Falcon
BANNED
Postby candle_86 » 2017-8-14 @ 21:40
Why go with 7950GT's, a pair of 7900GTX cards would be amazing, I have a pair myself, and why they can't be passivly cooled the run very quiet, i can't hear them.
Ryzen 5 1600 - Gigabyte B350 Gaming - 16gb DDR4 3200 - 240GB M.2 - Windows 10 Pro
Core i3 3470 - Dell B75 Mobo - 4gb DDR3 1333 - 500gb HDD - Windows XP
Opteron 180 - Epox EP-9NPA+SL - 2gb DDR500 - 320GB HDD - Windows XP
User avatar
candle_86
Postby agent_x007 » 2017-8-15 @ 08:52
Jade Falcon wrote:The 7950gt is a faster card.
Than a 7900 GTX ?
No, it isn't.
Check clock speeds, 7900 GTX has 650MHz Core clock and 1600MHz GDDR3 memory clock.
Default for 7950 GT is 550MHz Core and 1400MHz Memory.
You may be able to OC'ed 7950 GT to 7900 GTX level.
User avatar
agent_x007
Postby agent_x007 » 2017-8-15 @ 20:57
OK, I understand now.
I own 1TB VelociRaptor :)
Is your RAID setup faster than it ?
HD Tune Pro : Image
Additional tests : LINK
User avatar
agent_x007
Postby Jade Falcon » 2017-8-17 @ 04:21
Well this sucks, looking at the boards history in the bios, yes the board logs its usage, power offs, reboots, power on hours and average temps and fan speeds. Looks like the motherboard fans have been dead for a very long time. :dead:
I think i may just return the board and find a second one. It was sold to me as being in perfect working order, but all 3 fans are bad. Id hate to compete the build only to need to replace the board right after words. It's
Jade Falcon
BANNED
Postby Rawrl » 2017-8-17 @ 04:58
You might be hard-pressed to find one whose fans haven't died. Abit used some reeeeal shitty chipset fans around that time. (To be fair, so did everyone else.)
Rawrl
Postby Jade Falcon » 2017-8-17 @ 05:38
Rawrl wrote:You might be hard-pressed to find one whose fans haven't died. Abit used some reeeeal shitty chipset fans around that time. (To be fair, so did everyone else.)
Agreed. But tge sekker did state they were 100% wirking witch makes me mad.
And I have mote bad news. The hr-01 heatsink has damaged pipes. :dead:
My recent track record or used parts.
3 of 6 motherboards doa
1 board dead fans.
2 boards never shipped.
2 bad cpu's
4 bad sticks of ram
2 damaged sticks of pc166 but was simply fixable.
1 bad hdd
1 damaged cpu heatsink.
4 good video cards.
2 working sticks of ram.
One goid ls120 drive.
One good cd drive.
Talk about bad luck. I found that the ddr550 i gotns bad too :dead:
I need to find the witch that cursed me.
Well ill keep the board, but ill be bumping up my next build, this one sould not have anywhere as many problems.
Edit. OP edited. Bumping up my next build. The case is coming from Germany so it will take some tome to complete, but i have alot of oarts to mod and refurb before I can start. Suck as the water cooling system.
Jade Falcon
BANNED
Re: Project perfection. Vista era system, because why not.
Postby shamino » 2017-8-17 @ 06:03
Make sure the fan headers aren't burned out. Happens sometimes when fans seize up and overload the transistor driving them.
User avatar
shamino
Postby Jade Falcon » 2017-8-17 @ 06:32
shamino wrote:Make sure the fan headers aren't burned out. Happens sometimes when fans seize up and overload the transistor driving them.
Yeah there good.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-17 @ 16:58
OK aside from the GPU I made up my mind on all the parts. See the OP. I'll start prepping what parts I have tonight and post photos.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-17 @ 23:04
Well this is odd. The front rad houseing from the kandalf was cleared anodized aluminum. Odd that they would clear it.
Looks like ill need to Use something orther than paint stripper.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-20 @ 20:41
Ok some updates. I got a nos dfi x38 tr2b motherboard with a set of boxed 6990s. I know the 6990s are not quite vista era, but i could not find any 4gb 4870x2.
Jade Falcon
BANNED
Postby m1919 » 2017-8-21 @ 02:45
Where were you able to get your hands on a pair of 6990s?
Everything I'm seeing on ebay is like 500+ dollars now.
Looking forward to the build.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x QFSC 10C 2.9-3.3 GHz; 64GB Samsung DDR4-2133 ECC
2x EVGA 1080 FTW Hybrid; EVGA 750 Ti SC; Sound Blaster Z
User avatar
m1919
Postby Jade Falcon » 2017-8-21 @ 02:54
m1919 wrote:Where were you able to get your hands on a pair of 6990s?
Ebay, 150$ apice. With water blocks, I was the only bidder. I got stupid lucky somehow. I kind of wish i was out bidded. I really wanted to go dual 4870x2 4gb. But the 6990s had waterblocks and the original boxes.
I'm thinking of going UV orange, i dont think it will look all to good with a silver case. But the board has uv orange parts and I have some UV orange cables laying around.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-21 @ 23:25
Got some goodies today. For 2.50 a pice.
Jade Falcon
BANNED
Postby Jade Falcon » 2017-8-24 @ 16:08
I got the raid card, NIB. its so nice it even came with a enzotech heatsink. will post a photo tonight.
Jade Falcon
BANNED
Postby nd22 » 2017-8-25 @ 07:01
Hello Jade Falcon! I am also interested in building a Vista machine and I mostly succeeded in getting the components and assembling the machine for testing! It is based around Abit AW9D-MAX motherboard! Vista is such a good operating system with the right hardware; it's a shame it was released before it was truly ready!
PS: maybe if you are interested i can post the complete specs for the machine and my experience!
nd22
Next
Return to System Specs
Who is online
Users browsing this forum: oeuvre and 3 guests
