The $10 486
Reply 20 of 24, by probnot
0101000000110101 wrote:
Except my entire Gateway 2000 P5-120 setup that I should showcase! That, I FOUND.
I find I enjoy the systems I found or was given more anyway. They generally have a better story and mean more to me, for whatever reason.
Reply 21 of 24, by matze79
Check Cache Setting, maybe you have a WB/WT Jumpering mistake..
Reply 22 of 24, by probnot
Unfortunately, I don't know the exact model of the board, so the only jumpers I've been able to verify have been ones with screen printed info (cache size, freq, etc).
Reply 23 of 24, by bjwil1991
Found the motherboard info online:
Shuttle Hot-419 but your's has jumpers by the memory slots and Keyboard port, so I believe your board is a higher revision, but the chipsets do match the info online.
Reply 24 of 24, by probnot
That definitely looks like the one I have (though that one has the VRM, so maybe a higher end model or different variation?).
Either I didn't look hard enough, or you just know the right places to look. Thanks!
