harddrivespin wrote:Wouldn't a 2gb HDD be more than what was the norm during the 486DX4 time period? I'd expect something between 500mb and 1.2gb.
well i guess it is out of the norm, but it was the smaller SD Card that i had and i didn't even bother to try to find a smaller one because well, the bios supported the size and that was the limit for fat16 partition.
For the drives you can see that i didn't followed the period correct(like the 48x cd-rw drive, and the sd card).
clueless1 wrote:I think it's well spec'd out. I've got a 1GB spinning drive in my DX2/66, but BIOS only sees 504MB 😉 So I'm glad your BIOS allows full use of the 2GB. How does Quake play? I'm assuming you need to play in 320x200 to have any shot at double-digit framerates?
It runs actually pretty good(considering that is running on a 486 class machine), with the small screen is kind of playable for me,it is running on 320x200 and i had to resize the screen to get a better frame rate, i don't know if you have seen the build video but i show the quake running.
I may add some more pictures of the actual front of the case with the mod, it is not a real beauty, but the convenience for file transfer that i obtained mounting it to the front(on a empty 5.25 drive bay) is amazing.
and i'm currently working on a DIY Virtual Modem(its like a Wifi232).
