Packard Bell Legend 760 Supreme restoration
Showcase your Retro PC / Build logs.
Re: Packard Bell Legend 760 Supreme restoration
Postby Zorix » 2018-10-29 @ 16:52
Do you happen to have a master CD for the "Multi-Media" version of the PB410 or PB420 series? That was my first PC and the master CD was lost. I do have the master diskette boot disk that would then use the cd-rom to load the OS. The reason I got the Legend 760 was because it's the closest to that model I have seen for a reasonable price. Same motherboard, just didn't have the sound card or cd-rom drive.
You sure have a nice collection of Packard Bell computers! Should take a picture of them sometime. I would be interested in seeing them.
Thanks.
Zorix
Postby mperu99 » 2018-10-30 @ 03:20
Zorix, how do you want me to contact you? so i can send you the link
mperu99
Postby Zorix » 2018-10-30 @ 12:12
You can send a private message right here. Thanks.
Zorix
Postby Intel486dx33 » 2018-10-30 @ 16:47
Fantastic !
Great job !
Comment:
You can use lubercant and Isopropyl alcohol to restore the floppy drives.
Intel486dx33
Postby mperu99 » 2018-10-30 @ 16:54
Zorix wrote:You can send a private message right here. Thanks.
I do not see a private message link or button to send you a PM
mperu99
Postby Zorix » 2018-10-30 @ 18:46
Intel486dx33 wrote:Fantastic !
Great job !
Comment:
Thanks. I used lithium grease on the gears and the slide rails, and isopropyl for the heads. I haven't tested them since I try not to use floppy disks but i treated them right. They were later removed and put into antistatic bags and put into my collection storage for future use.
Zorix
Postby Zorix » 2018-10-30 @ 18:47
It's on the left side as a button under the avatar. It's a button that looks like a chess pawn or something like that.
Thanks.
Zorix
Postby mperu99 » 2018-10-30 @ 20:06
Zorix,
I am not authorized yet to do private messages... so just email me mperu99@yahoo.com
We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more to be able to use this feature.
mperu99
Postby Battler » 2019-7-08 @ 23:22
What exact Multi-I/O chip does it use? I know it's ACC3221, but I can't make it out from the photo if it's 3221-SP, -DP, or -EP.
Battler
Postby Zorix » 2019-7-08 @ 23:59
I zoomed in and it says SP on it. I would look at it closer but it's all assembled on the table and id have to take a lot of it apart, including the custom modem that sits on top of it. But I can clearly see the SP at the end in the picture.
Zorix
Postby amadeus777999 » 2019-7-10 @ 16:30
Very nice Job!
The mainboard looks pretty modern and compact.
How's the video output signal quality & Have you updated the cpu?
User avatar
amadeus777999
Postby Zorix » 2019-7-10 @ 16:40
I haven't done too much with it lately. I fully upgraded the CPU cache, the video ram, and got a DX2/66 but haven't installed that one yet. I put in a CD-ROM drive and a CF adapter for the IDE hard drive and a Gotek floppy emulator. Haven't touched it in a while. It did inspire me to work on my next project, replacing the CD-ROM with an emulator, so I designed a PCB to do that and I'm working on the logic side of that now. WIll be a while before I can get anything working yet but it will go into this machine first.
Zorix
Postby Monther » 2019-10-16 @ 05:41
Hi,
I have Packard Bell PB410A with BIOS saving settings issue with message real time clock failure.
Battery replaced with new one but problem not solved as settings reset every time restart system without removing power cord.
It's even not saving time, date or HDD details.
Any advise?
Monther
Previous
Return to System Specs
Who is online
Users browsing this forum: No registered users and 3 guests
