AMD 5x86 X5-133 (now with POD)
Showcase your Retro PC / Build logs.
Re: AMD 5x86 X5-133
Postby cxm717 » 2018-7-06 @ 19:00
derSammler wrote:While I have a spare Voodoo2, I don't see much point in testing that. The 486 can not fully utilize the Voodoo1 because it has to do T&L in software, for which it is not fast enough to push the Voodoo1 to its limits. The second TMU on the Voodoo2 won't help here, specially since it would only improve rendering speed if a game uses multi-texturing.
The Voodoo Rush is the only 3dfx chipset that works better with slow CPUs compared to the Voodoo1.
I've seen benchmarks showing the voodoo2 being faster than a voodoo1 even on a P100. I'm not really sure why. I have heard that it's because the voodoo2 does full triangle setup in hardware.
User avatar
cxm717
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-06 @ 19:12
On a P100, it's possible. Depending on the game, a P100 may no longer be the bottleneck for software T&L. But by no means the second TMU helps any when using a slow CPU.
btw, the Rush does triangle setup partly in hardware, too. That's why it is better for slower CPUs.
derSammler
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-06 @ 20:16
New results. :)
Sadly, PCI runs with 20 MHz now, since the M919 does not allow overclocking PCI. It does FSB/2 automatically for PCI if FSB is higher than 33 MHz. Overall speed is still much higher in all games, but according to Dr. Hardware, video speed lost more than 10 mb/sec. I may *have* to switch over to a good VLB card now to fully utilize the 40 MHz.
derSammler
Re: AMD 5x86 X5-133
Postby feipoa » 2018-7-07 @ 02:21
I also think it would be neat to see if there is any benefit, or lack of, when using a Voodoo2 on a fast 486. I haven't got around to this yet, but seem to recall reading that the Voodoo2 was faster on a 486 compared to the Voodoo1. It would be nice to have some benchmark numbers.
The automatic 2/3 PCI multiplier is one of the main downfalls of the M919. I recall someone using the turbo switch to boot the system up with 33 MHz FSB, then switching to 40 MHz in DOS. Did you confirm that the M919 doesn't divide the VLB freq when the FSB is set to 40 MHz?
User avatar
feipoa
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-07 @ 05:27
I don't see it as a downfall. It's actually quite surprising to see such a feature in a (cheap) PC Chips board. It makes sure that the system stays within specs, which is quite cool.
VLB is allowed to run at 40 MHz. While I have not tested the speed of VLB again (don't own a card that would show the difference anyway), I know that VLB always runs at FSB speed. You can't apply a divider to it, since it is not bridged but directly connected to the CPU - so it can not run anything but synchronous to the CPU.
The PCI divider could be avoided using an Arduino. Logic would be simple: on power-on or when reset signal is detected -> open JP3A. Speaker beep after post detected -> close JP3A until reset signal is detected again. But for now, I'm building a slot bracket with a switch for 33/40 MHz FSB.
derSammler
Re: AMD 5x86 X5-133
Postby feipoa » 2018-7-07 @ 06:43
I'd like to see a master override for the automatic 2/3 divisor, at which point, I'd not call the feature a drawback.
I did some testing which showed VLB+PCI boards having generally inferior PCI speeds compared to straight PCI/ISA implementations. For this reason, I tend to avoid VLB+PCI. However, the M919 is interesting with its fake cache history and COAST-like cache socket. viewtopic.php?f=46&t=46122
I tried the 33/40 switch trick on the M919 at one point and don't recall the outcome. I sorta recall it working, but having trouble with something else and getting fed up. I also thought of a small micro-controller switch idea at some point, but decided there are far better motherboards than to put more time into this one. The easiest implementation is to use a freq. to voltage IC, but can also use an Arduino w/comparitor+interrupt counter.
User avatar
feipoa
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-07 @ 14:54
Problem with the switch trick is that the IDE controller is PCI as well and doesn't run stable at 40 MHz. You can find some reports of people having done that and got data corruption from time to time. I'm not going to hot-switch the FSB. I built a slot bracket today with a switch that allows me to manually select 33 or 40 MHz FSB without opening the case. I'm going to use 33 MHz to not stress the hardware. Only if more speed is really needed, I switch to 40 MHz, but not while the system is running. In those rare cases, I can live with the performance loss of the PCI bus.
derSammler
Re: AMD 5x86 X5-133
Postby feipoa » 2018-7-07 @ 16:48
I too have run into the 33 MHz limitation of the onboard IDE controller on these boards and always run a PCI SCSI or PCI Ultra DMA controller.
User avatar
feipoa
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-08 @ 09:44
And here's the switch. Turned out quite nice. :)
derSammler
Re: AMD 5x86 X5-133
Postby BinaryDemon » 2018-7-08 @ 12:01
That switch is great!
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
BinaryDemon
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-08 @ 13:17
Looks even better assembled. :D
derSammler
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-15 @ 18:17
Now running with an original S3 Virge 325 instead of a Virge/DX.
derSammler
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-28 @ 17:41
Did a few changes today. S3 Virge replaced with a Matrox Mystique, Papst fan on the CPU, and some heatsinks added here and there. :D
derSammler
Re: AMD 5x86 X5-133
Postby feipoa » 2018-7-28 @ 23:10
No VLB graphics yet? It would be interesting to benchmark PCI vs. VLB on this board to see if it suffers the same performance degredation fate as SiS 496/497 boards when, both, VLB and PCI ports are included.
I'm curious about the decision to add a heatsink on the chipset?
Also, is that a memory upgrade module on the Mystique?
User avatar
feipoa
Re: AMD 5x86 X5-133
Postby melbar » 2018-7-29 @ 06:16
derSammler wrote:S3 Virge 325 instead of a Virge/DX.
derSammler wrote:S3 Virge replaced with a Matrox Mystique
What was the reason to go this way?
User avatar
melbar
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-29 @ 06:56
feipoa wrote:No VLB graphics yet? It would be interesting to benchmark PCI vs. VLB on this board to see if it suffers the same performance degredation fate as SiS 496/497 boards when, both, VLB and PCI ports are included.
The VLB slot stays reserved for a 3D Blaster, which I'm currently trying to obtain.
As for the heatsink, I read from various sources that the chipset can get hot when FSB is >33 MHz. And since I had a fitting heatsink lying around, why not? :D
Yes, that's a memory upgrade on the Mystique. It's an original one with 2 MB on-board + 2 MB on the upgrade.
melbar wrote:What was the reason to go this way?
I want to turn that 486 into a demonstration system for early 3D cards and I think the Mystique is a better fit. Too bad I can't use the Virge and the Mystique at the same time... The last free PCI slot will get a PowerVR card.
derSammler
Re: AMD 5x86 X5-133
Postby feipoa » 2018-7-29 @ 07:09
Oh. Have you ensured that the VLB slot is reliable with VLB graphic cards under stress in Windows? I personally had issues with the VLB slot on my M919 v3.4. My Diamond Stealth 64 Video VRAM (4 MB S3 Vision 968) would overheat in that slot, but not on other motherboards.
User avatar
feipoa
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-29 @ 07:13
I only have a Trident TGUI9400 for VLB and that one worked ok. No idea about more powerful cards, though.
derSammler
Re: AMD 5x86 X5-133
Postby Errius » 2018-7-29 @ 07:42
What external SCSI devices do you think you may need?
"I damn near killed an idiot who insisted on commenting in Klingon, but only on bits of inline assembler embedded in C ..."
User avatar
Errius
Re: AMD 5x86 X5-133
Postby derSammler » 2018-7-29 @ 07:51
Scanner, zip drive, Orb drive, tape library, hard disk, etc. I have a shitload of external SCSI stuff.
derSammler
PreviousNext
Return to System Specs
Who is online
Users browsing this forum: Robert B and 1 guest
