Toshiba T1800 386 Laptop
First post, by CarlHopkinsUK
So after a little absence from Vogons and having to sell all my retro pc stuff (thankfully all to other enthusiasts) - due to splitting from my long term partner and (ex) fiancee, and dealing with all the crap that brings with a house, banks, paperwork, and finding somewhere to live of course!
After getting settled down again i picked this little wonder up this week...
215.47 KiB
237.91 KiB
Toshiba T1800 Laptop from 1991 - 20mhz 386, no math co-pro, 2mb ram, 40mb hdd etc... and of course a monochrome STN display.
254.48 KiB
Unfortunately it does not boot and the in built BIOS suggests the HDD is dead - so a little tear down is in order.
309.59 KiB
Reply 1 of 27, by CarlHopkinsUK
Stripping down reveals a the largest 2.5" hdd i have ever seen...
216.35 KiB
Looks like normal IDE however, so my just drop a compact flash or something in here.
Whilst i was there i took a look at the built in 3.5" floppy drive, unfortunately it has a ribbon cable attachement...so seems a gotek is out of the question. Hopefully the drive will work with a clean up and service.
267.16 KiB
226.96 KiB
Reply 2 of 27, by LHN91
I've got an almost identical looking, slightly newer unit, the T1910CS. 25Mhz 486, 4 MB of RAM, Colour STN screen. essentially the same chassis though.
Looking forward to your teardown and to seeing what you do with it!
Reply 3 of 27, by Deksor
I've got that laptop. The HDD is just stuck in some way. Disassemble it and move the platters ans it might come back to life ! (I've fixed 2 Conner HDDs if that kind that way and now they're perfectly fine 😀 ). I as also remember having to unscrew the heads and screw them back on attend least one offre them but i'm notre sure if that's also required
Reply 5 of 27, by CarlHopkinsUK
Ah ok cool! Thanks for the tip, i will give that a try.
Reply 6 of 27, by Deksor
Whoops I just noticed, sorry for some words being wrong, text correction ...
Reply 7 of 27, by modbus
It is possible to connect Gotek Floppy Emulator. I had a broken belt in Citizen W1D floppy drive in my Digital HiNote Ultra CT475 docking station, and I made an adapter from 26 pin floppy to 34 pin Gotek, put Gotek inside, and it worked well. Now my 486 laptop has USB port sticking from one side 😀
Reply 8 of 27, by CarlHopkinsUK
Thats good to know that they work that way at least. I know there is a slimline version of the gotek available, so getting something to fit at least should be possible.
Likewise, the belt has failed in this as well, rest of the drive looks fine.
Reply 9 of 27, by CarlHopkinsUK
So i gave Deksor's suggestion a go...so apart again
252.64 KiB
...and inside
238.58 KiB
Unfortunately, the heads move freely so its not this causing issues...
Reply 10 of 27, by Deksor
That's how it was for me as well, but when I reassembled it, it worked again. Try to power it on while it's open
Reply 12 of 27, by bgonev
Any news on this topic ? Yesterday I've got a T1800 in very good condition, but unfortunately the HDD (MK1122FC) is not working. I've opened it to check if the head is stuck, but it is not a case.. The drive is starting to spinning for 5 sec then it restart itself (restart the spin cycle...). From what I've read on the net - the bios checks for the model ID (or name) of the disk, and if this is true, then IDE2CF with ANYDRIVE is not an option.
Any suggestions are more than appreciated - I want this baby up and running 😀
Reply 13 of 27, by Deksor
Maybe a BIOS mod could work ? It's not entirely impossible, but it's not easy either.
Reply 14 of 27, by pentiumspeed
Pick up any PATA drive even 100GB and put it in and set the capacity via BIOS setting like 500MB and use fdisk and format to see?
Cheers,
Great Northern aka Canada.
Reply 15 of 27, by bgonev
pentiumspeed wrote on 2022-06-13, 01:08:
Cheers,
Not possible with stock BIOS as there is no option to choose for the HDD model type (querying and autodetecting the HDD model/type at the boot time).
Reply 17 of 27, by Deksor
If you can dump the bios I'll try to have a look
Maybe we can at least change the hardcoded geometry or disable some checks
Makes me wish there was a pcmcia version of XTIDE (if that's even possible)
Reply 18 of 27, by TronadaSport
Hello everyone, if it was possible to modify the bios of the T1850 as it is done in other machines (T3200sx,t2000) that would be fantastic. I have had good results in those other laptops to install a CF card. In my T1850, I have desoldered the motherboard bios and read it with willem eprom and it could be edited and re-recorded. If someone has knowledge I can supply the original file to try to study the modification.
You have to manage to rescue these machines!!
    1.61 MiB
    t1850 bios
Reply 19 of 27, by Deksor
Well I can have a quick look at that, but I'm not an expert so don't have too much hopes. However if you post it here, maybe someone else will eventually see it. I'm gonna try to put a different HDD geometry as it's probably the easiest. Do you know what is the current HDD's geometry though ? I need the Cylinders Heads Sectors values.
