First post, by GabrielKnight123
Today I bought an AT case that has never been used its just been sitting in the guy I bought it from in his storage, it came with everything a new case does like a box of bits and pieces, and new power cord and a new power supply. He only wanted $50 and he threw in a couple of old PCs and AT power supplies and some other stuff. Here are some pictures below, im not sure what im going to put in this case yet but it should be a 486 with a turbo setting as the case has a 88 digit turbo with the letters "MHZ" next to them! so you would see "66MHZ". The front case has a sliding panel to get access to the turbo and reset buttons and the power button is a part of the black see through plastic - very nice. Let me know what you think of this case and if you recognise it as there is no name on it.
