AMD K6-3+@550mhz., Voodoo-3000 (tower)
Showcase your Retro PC / Build logs.
Re: AMD K6-3+@550mhz., Voodoo-3000 (tower)
Postby Intel486dx33 » 2019-6-11 @ 17:38
The Silver Aopen CDROM drive is starting to fail so I am going to replace it with this Sony 52x drive.
User avatar
Intel486dx33
Postby Intel486dx33 » 2019-6-19 @ 21:27
Finished with upgrades.
Now time to enjoy this build.
User avatar
Intel486dx33
Postby treeman » 2019-6-19 @ 23:34
Intel486dx33 wrote:
cde- wrote:Very impressive work!
Out of curiosity, how did you reball this BGA? Did you create a reballing mask specifically for it?
Actually, I do not have a stencil so I just reflowed the chip with some No-clean flux and a heat gun and it worked.
Did you actually remove the chip or just put flux under it and hair dryer it?
treeman
Postby Intel486dx33 » 2019-6-21 @ 18:19
These AGP Voodoo cards I did not reflow. They still work like new from manufacture.
The Voodoo cards I did reflow where PCI Voodoo-3 cards.
I just removed the fan/heatsink and reflowed the GPU chip and ram with some NO-clean flux. I did not remove the chips.
I just poured some NO-clean flux under the GPU chip and on the ram contacts and heated with heat-gun at 150c degrees.
That is the melting temp of the solder. Heat until all the No-clean flux is evaporated. I just let the solder do all the work of repairing the welds.
And it worked.
viewtopic.php?f=63&t=61265&hilit=reflow
User avatar
Intel486dx33
Previous
Return to System Specs
Who is online
Users browsing this forum: No registered users and 2 guests
