My Intel Plato/Premiere II build
Showcase your Retro PC / Build logs.
Postby derSammler » 2019-9-07 @ 11:55
After having mentioned it a couple of times here already, I thought I present my Intel Plato/Premiere II build.
* Intel Plato/Premiere II mainboard with 430NX chipset
* Intel Pentium 75 (gold cap) with passive cooling
* 2x 8 MB PS/2 FPM RAM
* ATi Mach64CT PCI, 2 MB
* miroSound PCM10 with OPL4 and 2 MB Wavetable ROM
* 3Com EtherLink III ISA network card
It's currently running Win95b from a CF card.
The turbo switch overclocks the CPU to 90 MHz with the display set up accordingly.
I'll post some more pictures soon.
derSammler
Re: My Intel Plato/Premiere II build
Postby oeuvre » 2019-9-07 @ 13:19
huh that's a cool case!
HP Z420 Workstation Intel Xeon E5-1620, 32GB, AMD FirePro V7900 2GB, SSD + HD, XP/7
User avatar
oeuvre
Postby derSammler » 2019-9-07 @ 15:17
Was a Cyrix 6x86 166 MHz originally when I got it. :D
More pictures.
Mainboard:
Dallas RTC socket:
derSammler
Postby blurks » 2019-9-08 @ 10:39
That looks like a very clean and stock system. I dig it, especially all those period correct components. The case looks fresh too, was it new old stock or just kept in good condition over the years?
User avatar
blurks
Postby derSammler » 2019-9-08 @ 12:17
Nothing NOS, I just gave all parts a good clean. The case was a bit dirty when I got it but was in great condition. :)
derSammler
Postby CuPid » 2019-9-08 @ 15:03
Nice build, and nice case.
derSammler wrote:The turbo switch overclocks the CPU to 90 MHz with the display set up accordingly.
How did you achieve that ? is that a feature of the Plato mainboard ?
I need a vacation.
User avatar
CuPid
Postby derSammler » 2019-9-08 @ 15:44
There's only a single jumper to change the FSB (ignoring 100 MHz, which this revision does not support). That's where I connected the turbo switch. Works even while the system is running.
Real turbo mode exists as well, but that is triggered by a hot-key.
derSammler
Postby gdjacobs » 2019-9-08 @ 17:09
What's performance like when you de-turbo (using the hotkey)?
User avatar
gdjacobs
Postby wirerogue » 2019-9-08 @ 17:38
Very nice. You have any more interior pics?
User avatar
wirerogue
Postby derSammler » 2019-9-08 @ 17:46
gdjacobs wrote:What's performance like when you de-turbo (using the hotkey)?
Did not use that feature yet, also no benchmark tools installed on it so far. Will test that later.
wirerogue wrote:You have any more interior pics?
I have to make some more. I somehow missed making pictures when the hardware was done and the case still open. :lol:
But I have to take out the CF card for backing it up anyway, so pictures of the interior will be made.
derSammler
Postby JudgeMonroe » 2019-9-08 @ 18:06
On a P5-90 the deturbo mode scores around 68 on Topbench, which is in the neighborhood of a higher-end 386. In practice this is good for older 386-era games but still too fast for anything that really wants that XT/AT timing.
JudgeMonroe
Postby CuPid » 2019-9-09 @ 08:15
derSammler wrote:There's only a single jumper to change the FSB (ignoring 100 MHz, which this revision does not support). That's where I connected the turbo switch. Works even while the system is running.
That's clever. I would not have thought that FSB could be changed on the fly (at least w/o fine tuning), but thinking twice the turbo on my 386 does simply do FSB/2 and can be changed dynamically.
I need a vacation.
User avatar
CuPid
Postby derSammler » 2019-9-09 @ 14:24
Finished software installation today and pulled the CF card for a backup. And made pictures during that, of course. ;)
derSammler
Postby Anonymous Coward » 2019-9-09 @ 16:19
I approve of this build, and extra points for going with a gold cap Pentium. I think not too many people build with a P75. The only thing I would change to make it more period correct is going with a Mach64 GX or a S3 964. The Mach64 GT is more of a 1996 thing.
I'm trying to put together something similar, only I want a Neptune board with dual P100 gold caps. I have everything except the board.
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby derSammler » 2019-9-09 @ 16:32
It's a Mach64 CT actually, did not notice that typo. Corrected. :)
derSammler
Postby gdjacobs » 2019-9-09 @ 18:18
Hmm... I wonder how that stacks with cache tricks.
User avatar
gdjacobs
Postby JudgeMonroe » 2019-9-09 @ 18:26
It doesn't. The deturbo mode on this board *is* (L2) cache tricks.
JudgeMonroe
Postby gdjacobs » 2019-9-09 @ 18:41
Ah, damn. Disappointing.
User avatar
gdjacobs
Postby JudgeMonroe » 2019-9-09 @ 18:50
gdjacobs wrote:Ah, damn. Disappointing.
The BIOS has separate settings for "Boot Speed" (Turbo or De-Turbo) and "System Cache" (Enabled or Disabled) but in my testing, either and both of these settings result in identical benchmarks, as does the deturbo hotkey. The documentation describes Deturbo specifically in terms of disabling the cache and "adding increased refresh cycles" but I didn't see any evidence of those extra cycles in the benchmark.
JudgeMonroe
Postby gdjacobs » 2019-9-09 @ 19:29
Sounds like they added some memory latency.
User avatar
gdjacobs
Return to System Specs
Who is online
Users browsing this forum: Google [Bot] and 2 guests
