First post, by derSammler
So here it is, finally done: my "Flytech Carry-1" socket 370-based mini PC from 2001. Interestingly, this model of the Carry-1 series seems to be unknown so far. The case is the same as the one used for the known 386/486-based models, but a bit longer since it has the PSU built-in.
Specs:
* Intel P3 Coppermine CPU running at 750 MHz (100 * 7.5, downclocked from 1 GHz)
* Intel 440BX chipset
* 256 MB RAM, PC100
* all the usual stuff on-board, incl. an S3 Trio3D/2X, which I'm not using, however
* PCI ESS Solo-1 sound card
* PCI GeForce4 MX 440 with 64 MB 128-bit DDR RAM
* 1 GB CF card mounted in on-board CF slot
* 40 GB Seagate Barracude IDE hard disk
Took me a while to get everything working, but it turned out perfectly. I can boot into a fully set-up DOS environment, Windows 98se (both on the CF card), and Windows ME (on the hard disk). Also made a partition for "data" (drivers, isos, installation files), which also holds image backups of both bootable partitions, one partition for software (tools, games, etc.), and one for temp/swap files.
I'll post some more pictures once I've closed the case.
http://retro-net.de/blog.html
Reply 1 of 9, by derSammler
More pics
Reply 2 of 9, by PC Hoarder Patrol
Nice - I do like these types of small system. What are the actual case dimensions?
I have a similar old ECS BookPC II that I've been meaning to dig out and see if it still works - could be just the spur I need 😀
Reply 4 of 9, by derSammler
More pics, case is now assembled (had to take care of two tiny spots of rust; also added two missing rubber feet).
Already installed and played some games on it, great fun! Next is getting my MS Force Feedback Pro up and running on this. 😁
    70.53 KiB
    Front
    70.94 KiB
    USB ports, normally not accessible from the outside
    118.02 KiB
    Back
Reply 5 of 9, by melbar
WELL DONE , this case is really nice 😀
Don't see a tiny small case with a touch of understatement really often. Do you know from which year this case comes?
You have downclocked due to thermal reasons, right?
Reply 6 of 9, by derSammler
The whole system is from 2001, as written in the topic title. 😉
The main reason why I run the CPU at 750 MHz is because I don't want to overclock the chipset. The CPU is 1 GHz at 133x7.5, but the mainboard has the BX chipset. While the BIOS allows running the chipset with 133 MHz (even maintaining the 33 MHz for PCI), I don't want to go that route. Not in that tiny case anyway.
Reply 8 of 9, by dr.zeissler
One ISA-Slot for the AWE64Gold and a pci-slot for a voodoo3
and that thing will be everything you will ever need.
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
