IBM PS/1 2155-593 Restoration
Reply 20 of 29, by keropi
theelf wrote on 2023-05-21, 00:26:
Ok, benchmarks... the difference is HUGE!!!!
nicely done!!!
but I have a question: what version of DOOM executable also calculates the FPS like you show on the pics?
Reply 21 of 29, by theelf
keropi wrote on 2023-05-21, 08:35:
nicely done!!!
Hi! is fastdoom
FastDoom. A new Doom port for DOS, optimized to be as fast as possible for 386/486 personal computers!
Reply 24 of 29, by theelf
Hi guys!!! dont know if ask here or start a new thread
About this IBM machines, i have some questions, someone managed to find ANY pin, connector, whatever to have a reset button? my good, this ibm pcs miss the most used function in DOS/Win3x 😀
keropi wrote on 2023-05-21, 12:05:
Ah thanks
Never really used it for benchmark
After Fastdoom i dont see any reason to use vanilla doom anymore, only nostalgic reasons. Of course, compare to old benchmarks is a reason
Reply 25 of 29, by totio
Yes, finally my kingston turbochip on IBM PS/1 see 160Mhz!!! Kid's dream!!!
Thanks epictronics, Thermalwrong
    286.31 KiB
    Kingston turbochip on IBM PS/1 2133-571
Reply 26 of 29, by theelf
totio wrote on 2023-05-22, 12:22:
Oh thats great!! i will love to have a 486/5x86 +100mhz in my IBM, but i dont find interposer in any place to buy, and overclock my DX4-75 to more than 100mhz i think will not work for sure. What combination did you use for 40mhz bus?
Reply 27 of 29, by totio
theelf wrote on 2023-05-22, 12:50:
R175 populated only.
Reply 28 of 29, by theelf
totio wrote on 2023-05-22, 13:04:
Thanks! yes, i believe, i tested yesterday i did same mod, and no boot, 40x3 is too much for the DX4/75mhz, but i wanted to be sure, thanks
Reply 29 of 29, by piteta
Hi, sorry for bumping this "old" thread. I have an PS1 (2168 552) that uses the same board that the one epictronics shows in his videos. I'd like to upgrade it but i have some questions. I already asked on the general forum, but no luck 🙁 So I guess is better to ask someone that has this computer:
- My main concern is the cache. I want to upgrade it to the maximum amount. ¿Is there any problem if I use faster chips than specified at the manual? I've looked at ebay for the UM61256ck-20 and they're more expensive than other faster 256kb chips. Should I pay attention to anything in special or go for a specific manufacturer? Maybe UMC is better than ISS? The idea is to install 16MB of RAM, altough may be in the future it gets upgraded to more ram (24 or 32 megs) if the games he plans to play don't have problems with that amount of memory.
-I thought that all overdrive chips were the same, but today I've learned that there are some that come with 169 pins instead of 168 pins, so I guess the cheapest and quickest way to upgrade the cpu is hacking the motherboard because a 168pin overdrive 486, should not disable the onboard 486SX. Am I wrong? (I already tried an ODPR and set the jumpers to 486dx, but it didn't work)
-The motherboard uses an hitachi ram chip for the video card. I guess it'll be better to use the same manufacturer for the ram, but do you know if i can use chips, for example, for siemens as long as they run at the same speed and have a compatible pinout?
Enough of your games Asthar, this is between you and me.
