First post, by Azarien
So I decided to upgrade my Core 2 Quad build to 8 GB RAM. Here is the specs:
• GA-P35-DS3L
• Core 2 Quad Q9550
• Radeon HD7850
• SB Audigy
• 2x 2GB DDR2 800 MHz Kingston
• 2x 2GB DDR2 800 MHz GOODRAM
• some HDDs
My problem is that the Kingstons and the Goodrams refuse to work together at 800 MHz. When I set 800 MHz for RAM, the system turns off and on by itself several times, after which the memory clock goes down to 667 MHz.
The Kingstons alone or Goodrams alone work fine at 800 MHz. So my understanding is that they are simply incompatible with each other at 800 MHz clock.
The system works stable at 667 MHz. Should I just leave it as is? Maybe it's possible to set all the CL values manually to get it to run at 800 MHz, but I don't know much about it. Buying more compatible RAM is also an option, but only if it's really worth it.
Is there any significant performance gain in 800 vs 667 MHz RAM for Q9550?
Reply 1 of 1, by pentiumspeed
P35 prefers good memory modules, DDR2-800 is also yes. Goodram is not a brand of memory modules. This is a business brand selling low quality generic memory modules.
Get more kingston or brand names like Crucial, Micron, Hynix etc.
I still have a P5K based on this chipset and it does work well with mentioned memory modules and at 800.
Cheers,
Great Northern aka Canada.
