Reply 260 of 661, by Eivind
- Oldbie
NRoach44 wrote on 2022-12-14, 07:31:tabm0de wrote on 2022-12-14, 07:25:Maybe in the future we can have parallel or simple scsi controller onboard 😉 so we can run our original cd games 😜
and ye sadly only ports that does take the space more then the components that are required 😒
That is if there isnt any real good fakecd's out there 😀I was thinking of making a modified TinyLlama with a PC/104 header, mainly for the flexibility allowing me to make other weird custom cards to slap onto it. It seems to be quite a versatile interface, with a not-huge footprint too.
Maybe I've seen too many of Rasteri's videos....
I've played around with this idea, there's one big drawback however - the ISA bus on the Vortex86EX isn't the full 98-pin 16-bit standard variant, rather something DMP calls "x-ISA" which has only 64 pins. The most notable omission with x-ISA is that it's only got a single DMA channel. That limits the usefulness of such an expansion.
