First post, by Guardshell
Hi all
I'm currently getting some parts together to build a new retro gaming PC:
So far I have:
PC Chips M810L Motherboard
AMD Thunderbird 1ghz (Socket 462)
3dfx Velocity 100
Dell 15" 4:3 Monitor (VGA Output)
What memory size is recommended for the system board 256mb / 512mb? PC100-PC133?
What size hard drive is good for that era of IDE drives?
Cant believe how expensive Voodoo cards are now, ended going for a velocity card because other voodoo cards are so expensive.
Any particular Sound Blaster version I should be going for on DOS / Windows 98 / XP?
Thanks in advance
Reply 1 of 2, by RandomStranger
Skip XP with this one. It will be !!!VERY!!! underpowered even for late Win9x games (post y2k), not to mention anything XP era.
Guardshell wrote on 2022-05-05, 15:21:
Faster is better. For W98/SE I never felt 256MB to be insufficient, but RAM is cheap, no reason not to get 512MB
120GB or less. You can probably get away with 40GB if you don't store that much CD images. Your graphics card is not all that powerful so that rules out most games that require a lot of HDD space.
They are, also non-essential.
Live! SB0060; SB0100; SB0220; Audigy; Audigy 2 ZS
Reply 2 of 2, by Guardshell
Thanks for information its a shame that the voodoo3 3000-3500/Voodoo5 are so expensive i just wanted access to the Glide era of games!
