First post, by Jackhead
I started to import me a PC-9801 from japan. First at all i need it for some scsi based hardware that need the real hardware.
There serval models, at the time i found this working one.
It runs a 486 DX2 66 with 18MB RAM, has two IDE ports, a 34pin Floppy header as well. So perfect to run some games old/new.
The MB itself has no caps, but i recapped the PSU and add a new fan.
I added two HxC Slim board as floppy emulator. Got it working. Also primary IDE a CF adapter as boot HDD running Dos 6.20
For sound i choose a pc9801-86 and a Roland MPU-PC98II
Next step will be adding a front bay cf adapter for data transfer on second IDE port. System runs really great and its really impressive how easy c-bus works.
Also need to change the battery.
Here some shots *work in progress*:
685.34 KiB
1.05 MiB
1.41 MiB
1 MiB
1.53 MiB
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 7, by MrSmiley381
Oh man! I love seeing Japanese PC's on here. We don't get enough of 'em. Please keep us posted on any updates/troubleshooting/experiments you do with this. What games are you planning to run on this beast?
I spend my days fighting with clunky software so I can afford to spend my evenings fighting with clunky hardware.
Reply 3 of 7, by Jackhead
I changed the battery (ML2340) and installed the CF frontbay. Was also very easy, set to master, second IDE Port and it shows up. I had trouble formating cf cards on the system. So i used also the yahdi image and delete all the files, works fine for me.
The only thing im missing is a adapter for the joystick port. It use direct input like the MSX. So if you want to use a mega drive controller for example you need an active adapter.
I really need one, the arrow keys are horrible when you used to western ones.
To the Games i want to play Night Slave, Rusty and some shmups. Will see, so many games i dont know..
SCSI i need for a devkit in this timeline, where software only work on pc98.
Afterall pretty happy with the pc
531.44 KiB
Reply 4 of 7, by lolo799
You're right about the arrow keys, they look uncomfortable to use, give Doom a try please!
I should have asked directly what kind of devkit do you need a PC-98 for, I imagine something 8 or maybe 16bits but no later, right?
Reply 5 of 7, by Bendejo
Been looking to get into the PC98 scene but i'm doing the research first. I am leaning towards an A series 9821 which will give me a good range of compatibility, but also looking at 9801 DO which will let me play PC88.
Reply 6 of 7, by madalex
Jackhead wrote on 2022-08-04, 16:52:
I started to import me a PC-9801 from japan. First at all i need it for some scsi based hardware that need the real hardware. Th […]
Question: Did you sell this built to germany? I´ve just bought an 9801 BA2 of german ebay and basically its the same build (contains the CF card reader + Card). The drives are missing and anything else, probably ripped from it.
BR
Alex
Reply 7 of 7, by Jackhead
Yes, i switched to a PC9821.
