IBM PC 330-P90
First post, by soupapes
I cant resist old IBM's, so I bought this lovely 330 Pentium 90, and it came with an IBM Auto 16/4 Token Ring ISA network card.
I have installed windows 95 OSR2. It detects the network card but the windows driver does not work with it.
Also tried a driver I found online but run into same problem.
Anyone knows where can I find the right working driver for this card?
- IBM Aptiva 2176/P166/Matrox Millenium 4Mb/Voodoo1 4Mb/48Mb/8Gb+8Gb SD-IDE/SB16/Win98SE
- 486 DX2 66/CL-GD5424/32mb/HD 600mb/Mozart601/Dos6.22+Win3.11
- P166MMX/S3VirgeDx/96Mb/8Gb SD-IDE/SB16/Win98SE
- P4 3GHz/FX5700/2Gb/HD 80Gb+160Gb/Win XP
Reply 1 of 27, by PC Hoarder Patrol
soupapes wrote on 2022-11-05, 23:22:
I cant resist old IBM's, so I bought this lovely 330 Pentium 90, and it came with an IBM Auto 16/4 Token Ring ISA network card. […]
You don't mention which other drivers you tried - was it these? https://www.driverguide.com/driver/detail.php … driverid=134767
Reply 3 of 27, by soupapes
PC Hoarder Patrol wrote on 2022-11-06, 00:50:
I did try those and followed the instructions but still no luck. Maybe there is an issue with the card.
I will try later to install it in a win98 machine.
Reply 4 of 27, by luckybob
UMM. please tell me you are NOT trying to use a token ring card on ethernet. It is NOT compatible in any sense of the word.
Reply 5 of 27, by soupapes
luckybob wrote on 2022-11-06, 17:31:
Good to know that... 😁
Reply 6 of 27, by luckybob
I have a big box of token ring stuff. Stuff that I plan to "get a round to it".
Maybe one day, I'll win a battle against my ADHD brain and learn token ring.
Reply 7 of 27, by AlessandroB
Just a little information aside... on this computer (i have the P75 version) work perfectly the 233Mhz Pentium MMX CPU, you have a superb DOS station...
Reply 8 of 27, by eisapc
The driver will not load, because the system is not able to insert to the token ring as long as it is not connected to a MAU like an IBM 8228 or something equivalent.
There are token ring switches availiable as well as token ring boards with 100 MBit, but without an ethernet to tr bridge you will not be able to connect to an ethernet.
Still have to check the setup for my ethernet to tr connection over 155Mbit ATM fiber using the ATM uplinks of a fore ethernet swich and olicom tr switch.
Reply 9 of 27, by soupapes
I was not familiar with this token ring card. Nevertheless it does not fit my purpose so I will replace it with a regular network card. I want to use it in my home network to share files using ftp.
Reply 10 of 27, by Riikcakirds
AlessandroB wrote on 2022-11-07, 16:04:
Problem is the IBMPC-330/350 series used a few different motherboards. The one in this post is an Intel Advanced/MN Morrison64 with onboard Trio64. I have the same in a IBM-PC330. It says it only supports up to a P120 in the official Intel docs. I have got it working with a P200 by joining the BF1 pin on the CPU to VSS ground (pins are next to each other) with a thin wire.
https://theretroweb.com/motherboards/s/intel- … d-mn-morrison64
The IBM version has a blue bod wire attached to the chip enable pin of the bios. If this is the same board you have how did you get a mmx chip working (running it over-voltage)?
There is also a MR-BIOS 3.46 for this board (V097B5NA - it's on vogons drivers https://www.vogonsdrivers.com/getfile.php?fil … 810&menustate=0 ), it's much better than the latest IBM bios and supports Hard Disks up to 128GB with bus master MW-DMA2 in DOS.
Reply 11 of 27, by soupapes
I have updated the BIOS in mine. It come with a bios dated in 95 and now I believe it has the latest IBM bios dated from 98.
Reply 12 of 27, by Intel486dx33
I love those old Desktop IBM computers. This is what I learned computers on IBM AT, IBM PS/2, PS/1 and these Desktop Pentiums.
I have very fond memories of these IBM computers.
They never let us down and were always working.
Very 1980’s and 1990’s
I like how clean than simple they look with the front bay door closed.
What really set IBM apart from all the other computer manufactures was the programs, menus, and tools and batch files they included with
The installation software which made the computer easy to use, administer, maintain and manage.
I would try to find an original recovery disk.
This might work:
Re: IBM Desktop PC-750 , Pentium-90 Restore.
Reply 13 of 27, by soupapes
Intel486dx33 wrote on 2022-11-09, 15:01:
I love those old Desktop IBM computers. This is what I learned computers on IBM AT, IBM PS/2, PS/1 and these Desktop Pentiums. I […]
Very 1990’s
What really set IBM apart from all the other computer manufactures was the programs and tools and batch files they included with
The installation software which made the computer easy to administer, maintain and manage.
I agree with you. And I deeply regret having sold my first computer, An IBM PS/1 486 SX 25. I still keep the original SVGA monitor from it.
Still trying to find one for a reasonable price.
Reply 14 of 27, by Unknown_K
I worked on somebodies IBM system with that style case, but it had dual PPro's with the full 1MB cache (black top). He offered to sell it to me cheap, but I declined (this was 15 years ago).
Nice system.
Reply 16 of 27, by H3nrik V!
luckybob wrote on 2022-11-10, 07:50:
The dual p-pro ibm machines are hard to find. Ask me how I know.
How do you know? 😉
Oh, and the summoning spell is now just "dual" ...??? 🤣
Reply 17 of 27, by AlessandroB
Riikcakirds wrote on 2022-11-09, 13:00:
Problem is the IBMPC-330/350 series used a few different motherboards. The one in this post is an Intel Advanced/MN Morrison64 […]
yes run in over voltage, but is absolutely not hot and… i have many MMX chip. How to know wich mainbord is?? there is a list somewhere?
Reply 18 of 27, by Riikcakirds
Look for a yellow or white label by the CPU socket with "fru 96g3576" printed on it.
Have you tried the MR-BIOS to enable 128GB Hard drive support.
Reply 19 of 27, by ArtiomWin
This might work:
I would like to get that recovery CD (or Ready-to-Configure CD) too, as the one I've provided is for 486-based 300 Series models. The closest thing we've got is IBM Aptiva Multimedia Exploration CD dated 1995-03-29 here. That's recovery CD for IBM Aptiva 720 (2144-S15) which was based on the same Morrison/64 board as this IBM PC 330 (it has a bit different revision of BIOS).
