The Pentium 4 3.06ghz/512/533 478 arrived today. Unfortunately I'm getting no picture after installing it.
EDIT1: Trying CMOS clear
EDIT2: Still not working
EDIT3: It seems I made a rookie mistake. I didn't pull the lever before inserting the processor. I took it out, looked that it seemed fine and tried to put it back correctly. It still didn't work. I took it out, put the old one back and looked at the pins of the new one more carefully and it seems that a couple of them at the corners are a little bent. If I straighten them will the CPU still be functional? I think it was seated properly however the second time it was in the slot and I guess it wouldn't go properly if the pins were too badly bent?
Anyway, I guess, I'll just settle with the old one or try to update the BIOS and microcode if that would help.
EDIT4: My MoBo doesn't support booting from USB and updating the BIOS with Fujitsu Siemens DeskView didn't work. The next step is buying some floppy disks.
