RetroMaster137 wrote on 2023-11-05, 19:05:
doing its maintenance just right, could it last for like, 20/30 more years with occasional use?
Hi. Let's suppose your target is to make this system work without component replacement until 2053. Obviously the economical sense of such an asset is nil because it's full of common parts with no collectible value. But let's take as granted that you are serious, after all we are not gathering here for rationality. Besides the following applies to any other computer. Lay out an O&M routine along the lines of:
- dusting every year (every 6 months if house has pets / harsh climate)
- nb and cpu thermal paste replacement every 3 year.
- gpu thermal pad replacement every 5 years.
Run-to-breakdown: all the fans. 120mm fans are not going anywhere anytime soon, no need to hoard them. The tough part may be gpu cooling solution fans with specific mount, so it's a point to consider. Though even if you decide to stock on them ahead the grease may dry over time in storage. Make your inventory and establish a routine for monitoring the stock condition (bearing noise) every 3 years.
PSU may also be a point of consideration though I firmly believe there will still be enough ATX 2.x PSU's in stock by 2040s-2050s. Considering the enterprise market the full adoption of new standard will take decades and even after that there would be adaptors, the same as you can power a BabyAT board with ATX 1.x PSU today. Solution is investing in A-tier 80+Gold or higher PSU now and shop for the next one in 2035-2040, that brings you to 2053.
It's in my plans to buy more 8GB DDR3 sticks (the maximum I can find on DDR3) before they get discontinued
It won't be an issue even in 2040-2050 because DDR3 has little defects and isn't even discontinued just yet. Finding secondhand DRAM modules in working state is the least of an issue in building pc.
unless I can actually find a PRO A10-8850B
If you are keen on it, set a watchdog and buy just once when it surfaces. The performance gains of medior updates will be minimal.
more thermal paste IF it ever gets discontinued
Won't be an issue and it's counterproductive as liquids have limited shelf life.
and I got some working HDDs stored somewhere.
Unless you specifically want a spinning drive you shouldn't have problems with cheap SATA SSD storage in 2040-2050, those will likely be produced well into 2030s in quantities enough to make stocks last for 10-15 years. If you want a good mechanical hard drive it's a hunting game that gets harder every year.
I don't know if should I get another motherboard of the same model before it's too late, just in case.
It's not a bad idea if you are adamant about this very model. Seen that it's low value those won't be resold as collectible items and will go to e-waste in 10-15 years time.
You needn't stock on caps now because those have limited shelf life. There are procedures recapping stuff in a planned manner for extra long storage life, think every 10 years for poly's and 5 years for elco's if you are serious, double if you are lax and your stuff just works.
Believe it or not I can STILL play many modern games at decent speeds IMHO (I'm CPU bound)
Steam drops Windows 7 and it will drop Windows 10 in just a 10 years time so it's not sustainable for your end goal. Your options to make it to 2053 is to stay offline with WinXP/7 and use either DVD hard copies or DRM-free releases offline installers from GOG.
lack of VESA support from the dedicated GPU (though the integrated GPU works like a charm)
There are indeed VESA modes troubles with newer cards but that goal sounds outside of the general scope. With oldest PCI-e cards such as Radeon X800 you should be ok-ish DOS compatibility-wise but that's probably not the point.
RetroMaster137 wrote on 2023-11-05, 19:05:and lack of SoundBlaster card
You have 32-bit PCI slot for SB Live!, 8738 or whatever supporting DOS natively.
RetroMaster137 wrote on 2023-11-05, 19:05:I bet if I find a diskette drive and necessary adapters I could install MS-DOS 5 and run Windows 1.0 on it.
Succeeding in this will be difficult with a usb floppy drive and lack of FDD and IDE controllers. Things like that mostly ended during AM3+ era and SB9xx chipsets for AMD, some 2 years prior to your configuration. Your viable option is FreeDOS.
[/quote]
RetroMaster137 wrote on 2023-11-05, 19:05:I'm just not going to find this high level of compatibility on a newer PC.
Nothing leads to that conclusion. This system is about as incompatible with old stuff as a modern Ryzen.
