Tomb Raider I NGlide-DOSBox Intel Graphics
General information and assistance with OpenGLide.
Postby fil » 2013-8-07 @ 22:09
hello all,
I'm running tomb raider I with NGlide through ykhwong DOSBox SVN-Daum 25 June 2013, works absolutely to perfection on my PC with Core 2 Duo and Geforce 512MB card
on 2 other pcs, 1 which is a Pentium D with Intel(R) 82945G Express Chipset Family, and the other is a P4 3.0Ghz with Intel® Extreme Graphics Driver for 845 Chipset, both onboard, tomb raider crashes just before the 3dfx splash screen and dosbox exits
i know these cards are missing TnL caps Pixel shader, but both these PCs with onboard Intel Graphics actually run tombraider perfectly ok with both dgvoodoo and glidos, so i wonder if there's any way to get it working on DOSBox?
thanks a lot
fil
Re: Tomb Raider I NGlide-DOSBox Intel Graphics
Postby Kaminari » 2013-8-08 @ 21:26
You might be in the wrong section.
Or have you tried using OpenGlide instead of nGlide?
Ryzen 2600X 4.0 GHz | Vega 56 8 GB | DDR4 16 GB | Win7-64 SP1
User avatar
Kaminari
Postby fil » 2013-8-10 @ 18:39
thanks for your reply
does tomb raider work with openglide? the guide i found tells you to replace glide2x.dll in root dir from dosbox (daum or gulikoza versions) with the one from nglide (in windows system32 folder)
i did test it with the glide2x.dll that comes with ykhwong dosbox daum and it only worked with glide=emu (which runs really slow). on glide=true it crashes just before the 3dfx splash
fil
Return to OpenGLide General
Who is online
