Aiming for a release
Developer's Forum, for discussion of bugs, code, and other developmental aspects of OpenGLide.
Postby Glidos » 2003-4-22 @ 21:03
Hi Fabio (if you are out there),
Just before you got busy, you were looking to release a final v009. Back around that time, I tried out the most up to date version from CVS, found a few problems, and didn't have time to look into it. Now, I've had another look, and there were only two little problems, which I've fixed.
Do you think I should release a 009rc5, and ask for some testing to be done.
Also, do you mind if I get rid of the binary files we are holding in CVS (like the .ncb file). As far as I know, these only serve to cache info that is in other files, and keep unimportant stuff like which target you last built, and what layout of windows you like.
User avatar
Glidos
Return to OpenGLide Development
Who is online
