OpenGlide FAQ?
Developer's Forum, for discussion of bugs, code, and other developmental aspects of OpenGLide.
OpenGlide FAQ?
Postby DosFreak » 2002-12-07 @ 16:42
Is there one?
Common questions/issues we've encountered?
User avatar
DosFreak
Great Idea
Postby GoldFinger » 2002-12-07 @ 18:03
That is a great idea, but we need a volunteer to do that, would you be the one? :P
GoldFinger
Postby Nicht Sehr Gut » 2002-12-09 @ 00:52
OFFICIAL OPENGLIDE FAQ
Q: Is there one?
A: Yes. A short one. You're reading it.
Q: Any Common questions/issues encountered?
A: Yes, "Is there an OpenGlide FAQ?" and
"Any common questions?" seem to be popular queries.
User avatar
Nicht Sehr Gut
Postby Glidos » 2002-12-09 @ 07:34
Q: Are there any as yet unanswered questions that the developers would like help with?
A:
User avatar
Glidos
Postby Stiletto » 2002-12-09 @ 19:47
Ideas:
A description of each-and-every OpenGLid.ini setting would be good - and when you might need to enable/disable one.
What certain errors in the log mean (hard to update, though)
... and the obvious stuff...
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby Snover » 2002-12-09 @ 20:52
Someone that's in the know about those OpenGLid.ini settings needs to send me a PM/email. I'll start writing up the docs.
Q: How do I get this to work?
A: Either put Glide2x.dll in the game's directory or in your WINDOWS\SYSTEM32 directory.
Q: How do I change settings?
A: The first time a game is run with OpenGLide, it will create an "OpenGLid.ini" file in the same directory that it is located in. Edit that file to change settings. Hopefully later on there will be an MFC application to change settings with more easily. *hint,hint*
Snover
Options
Postby GoldFinger » 2002-12-15 @ 03:43
for someone to do the FAQ, these are what the options mean:
0 means disabled
1 means enabled
CreateWindow:
Creates a new window for OpenGlide to run.
Can be Enabled or Disabled.
InitFullScreen:
Tells if OpenGLide is to run in FullScreen mode or in Windowed mode.
EnableMipMaps:
Enables the auto generation of MipMaps, can improve the performance/visual quality, but it is better to test both ways.
IgnorePaletteChange:
If the boards supports palette extension this has no effect, otherwise it can improve performance but reduces visual quality.
Wrap565to5551:
This one is for OpenGL 1.1 boards only, it maps the 565 texture format to the 5551 one if enabled, if disabled the 565 format is mapped to 8888. Enabling it can improve performance, but it is better to test both ways.
EnableFog:
Enable fog support in OpenGLide.
EnablePrecisionFix:
If the board only supports 16bit Z-Buffer this option can solve some z-buffer problems, it will be disabled automaticly if the z-buffer is greater than 16bit.
EnableMultiTextureEXT:
Enables the use of MultiTexture to improve performance.
EnablePaletteEXT:
Enables the use of the Palette extesion (if present) to improve performance and visual quality.
EnableVertexArrayEXT:
Can improve the performance, must be tested.
EnableFogCoordEXT:
Uses the extesion to improve fog support.
TextureMemorySize:
The ammount of Texture memory present, can be from 2 to 64 MB.
WrapperPriority:
The priority of the OpenGLide wrapper, with the following table:
0 - Priority = THREAD_PRIORITY_HIGHEST;
1 - Priority = THREAD_PRIORITY_ABOVE_NORMAL;
2 - Priority = THREAD_PRIORITY_NORMAL;
3 - Priority = THREAD_PRIORITY_BELOW_NORMAL;
4 - Priority = THREAD_PRIORITY_LOWEST;
5 - Priority = THREAD_PRIORITY_IDLE;
FrameBufferMemorySize:
The ammount of Frame Buffer memory present, can be from 2 to 64 MB.
GoldFinger
Re: OpenGlide FAQ?
Postby Dan Forever » 2006-4-24 @ 17:12
Is Openglide just an open source wrapper to opengl? It doesn't do any emulation other then that, so unlike dosbox I can't play old windows glide games under linux? Or does it work in conjuction with wine?
User avatar
Dan Forever
Re: OpenGlide FAQ?
Postby Glidos » 2006-4-24 @ 18:28
Simon White updated it to build for Linux. You should ask him (via sourceforge) about running under wine.
I do know that he is working on a dosemu version too, and close to having something working I think.
User avatar
Glidos
Re: OpenGlide FAQ?
Postby gulikoza » 2006-4-25 @ 06:58
I have a very early version of glide support for dosbox, which can be used in conjunction with openglide. The patch is being evaluated by dosbox developers so it's not public yet but I believe ykhwong's build does include it. But it's not very stable atm :)
User avatar
gulikoza
Return to OpenGLide Development
Who is online
